Author Topic: Stock CB650 runs rich...unless no air filter....  (Read 2194 times)
Offline BikeKayakSki
« on: July 30, 2016, 12:35:15 PM »
Hey folk, I have an odd issue with my 81 cb650. The bike refuses to pull above 6k and has no power up there, it just starts misfiring. I rebuilt the carbs and used stock main jets, and cleaned the hell out of everything else. The bike also has new plugs, and a new stock style K&N air filter in the airbox. The bike idles fine, and pulls off from a start pretty well.
Here's the weirdness, if I run the bike with no air filter, it pulls and runs great all the way to redline, NO ISSUES. Not a hiccup anywhere. Which is weird, because the bike should be running super lean with the filter out, and is indicated as such through the plugs, but not as lean as I would expect. This is really confusing to me because of the fully stock setup I have going on here. But the stock setup seems to be making the bike run rich, which is leading to misfires at high rpms.
So what do I do here? I was seriously considering putting a screen in the airbox to keep serious junk out and run it as such, but I feel like that's the easy way out.
Anyone have an idea?
Offline Steve_K
Re: Stock CB650 runs rich...unless no air filter....
« Reply #1 on: July 30, 2016, 01:31:34 PM »
A dirty filter can cause that.  Maybe an old one could not flow due to age.
I assume there is no sock over the intake opening?
Steve
Steve_K
« Reply #2 on: July 30, 2016, 02:22:25 PM »
Hey Steve, as stated it has a brand spanking new stock style K&N air filter in it. My old filter was very clogged, and the bike wouldn't do much above 5k with that in. The new filter got me about another 1 to 1.5k more in the RPM range, but thats it.
As far as a sock over the intake...no there is not. Where would that be located if it was installed?
Offline jonda500
« Reply #3 on: July 30, 2016, 06:08:42 PM »
Sounds like going one size smaller main jets could be worth a try? (or get an oem air filter or use less oil on the k&n filter.)
John
A starter clutch thread:
« Reply #4 on: July 30, 2016, 08:12:48 PM »
Did you over-oil the K&N filter? They usually come pre-oiled, and can be installed straight out of the box, after removing the cellophane wrapping, of course.
« Reply #5 on: July 31, 2016, 05:27:53 AM »
Jonda: I'm really thinking about going the smaller main-jet route. A thought occurs too, I took the vacuum petcock off my carbs, so the fuel is being gravity fed now. With this kind of mod is it necessary to rejet?
Scottly: I didn't put any extra oil on the K&N, so its strait out of the packaging at the moment.
Offline jonda500
« Reply #6 on: July 31, 2016, 05:43:12 PM »
Changing the petcock wont affect the mixture - you did close off the vacuum port that used to open the petcock right?
John
« Reply #7 on: August 01, 2016, 05:54:47 PM »
John: Yeah I plugged the hole in the #2 carb.
I did a bit more research, and found that some early 80s 650s run way better with the airbox lid off...so I found some washers to hold the air filter in place and ditched it. Runs like a champ now.
DH
« Reply #8 on: August 02, 2016, 06:16:03 AM »
You might check this out.....http://manuals.sohc4.net/cb650/technical_reference/SB650_1.pdf
