Author Topic: clutch and cable not engaging.  (Read 1156 times)
Offline la ca fe
« on: August 01, 2016, 10:54:20 AM »
I recently changed my bars on "72 cb750 back to stock ones. P.O. had some country western looking, extended bars that this bike didn't want. I did the swap back to stock and now the clutch wont engage but it did before the stock bars were returned on the bike. I set the cable adjustment all to way out to put more pull on the cable, both on the lever side and down on the engine side, but no dice. I am using the same cable that was on the bike before the bar swap, it looks to be the stock size and in decent shape.
The bike just lurches into 1st from neutral when clutch in engaged and I am trying to ride away from a stop.
Anyone solved this problem in the past?
\Thanks.
1976 cb750k
1976 cb750f
1975 cb750f
1970 cb750
1977 xs750
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: clutch and cable not engaging.
« Reply #1 on: August 01, 2016, 11:14:44 AM »
Assuming the clutch adjustment marks are aligned, you may be facing a symptom of a cable that is too long.
Something I learned building bicycles.  If cable and housing are excessively long, the bending and twisting will result in the pulling force being exerted elsewhere.  Rather than its intended target.
Which is why shifting and braking on department store huffy's often suffer.
Offline la ca fe
« Reply #2 on: August 01, 2016, 11:54:05 AM »
Very interesting. I will get a new, stock cable and give it a try.
Haha. I remember the Huffy well, my sister had a "Sweet Thunder" in pink.
1976 cb750k
1976 cb750f
1975 cb750f
1970 cb750
1977 xs750
  • Holy Cow! I'm a
« Reply #3 on: August 02, 2016, 12:00:39 AM »
I wanna see these country western bars.
Waaaaiiiitttt.
Handlebars, country western handlebars.
Offline la ca fe
« Reply #4 on: August 02, 2016, 10:02:31 PM »
changed the cable. It was too long and didn't engage the clutch. New one works great!
Thanks.
1976 cb750k
1976 cb750f
1975 cb750f
1970 cb750
1977 xs750
