Author Topic: Can we talk about rear sets?  (Read 7535 times)
Offline Scott S
Re: Can we talk about rear sets?
« Reply #25 on: January 23, 2020, 11:34:07 AM »
The early cb400f pegs bolt right on the cb550 frame. The shifter side is perfect fit but the right side needs a bit of grinding to make space for the kick starter.
Sent from my LG-H812 using Tapatalk
 Not quite.... see the link above. You need to heat and bend the brake lever and find a 550F kicker. I like flipping the heim joint on the shifter side, too. And I've had to slightly enlarge the hole for the locating pin as well.
 I've never used them on a 550F model. You may run into issues with the way the F model brake pivot mounts, among other things.
 The Tarozzi stuff is nice and well made.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline DaveBarbier
« Reply #26 on: January 23, 2020, 11:45:41 AM »
Haha, I think I've got a fanboy thing going for Kott too. I made my seat after his design as well.
They worked just fine, Sean. They have oilite bushings and were very smooth. I welded a bracket for them just above and behind the stock foot peg location. I ended up removing them because I was getting back and hand pain. I'm pretty short so the rearsets gave me too much hand pressure and they would go numb after about 20 minutes, even with oury grips.
Can you show me how you made the bushings?
Damn, this post was from when I was just a lad.
I didn’t make the bushings, I used bushings from the hardware store that were the correct size.
Offline Kelly E
  • Geriatric Hooligan
« Reply #28 on: January 23, 2020, 12:40:38 PM »
I flipped my 550 mounts over and cut off the peg mount. Then I used 82' Honda V45 Sabre peg mounts welded on.  I was able to use the stock pegs with a little grinding. The Sabre peg mounts have a remote shifter and it fits. I shortened and bent the brake pedal. I don't have to prove anything so the kickstarter is ornamental. No pictures because they are still in pieces after paint.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline Rockreef
« Reply #29 on: January 23, 2020, 01:17:35 PM »
Might help. My build process in my build thread.
http://forums.sohc4.net/index.php/topic,140833.msg1637092.html#msg1637092
thank you! Gonna take a read through. Super stoked you’re still here, lad!
Offline Rockreef
« Reply #30 on: January 23, 2020, 04:14:28 PM »
Okay so essentially you drilled and tapped the pegs and threaded a bolt in from behind the aluminum plate? And the bronze bushings sit on it between plate and peg? What size bolt did you go with? Assuming SS? And what wall thickness for the collar that the levees are welded to?
I’m gonna copy that but use slightly different pegs and bolt the assembly to an aluminum bracket which will bolt to my passenger peg holes.
