Author Topic: 1982 650 SC Nighthawk will crank but not start  (Read 897 times)
Offline 82650sc
« on: August 02, 2016, 07:31:41 PM »
82 nighthawk won't start. The carbs are getting fuel, the spark plugs are new and getting spark, the battery is fully charged. I am wondering what else could be the issue. There are a few tubes near the carburetor that are not connected to anything, could that be the issue or are they just breather tubes? Note: My petcock is broken. Could this lead to the engine being flooded?
« Last Edit: August 02, 2016, 09:53:33 PM by 82650sc »
Offline eigenvector
Re: 1982 650 SC Nighthawk will crank but not start
« Reply #1 on: August 02, 2016, 08:05:43 PM »
I have an '84 CB700, don't know how different the carbs are - but something I learned from it was that it simply wouldn't start without the vacuum petcock fully installed.  Same with my '83 Sabre.  They appear to need the petcock installed properly.
If the openings you mentioned are what they are on my CB700SC, they're just vent tubes and aren't too important.  On California models, the '84 had an EGR type device hooked to the carbs as well
All said and done - confirm that the petcock is installed properly, other than that ensure the enrichment circuit is working properly - the springs can get sticky.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline 82650sc
« Reply #2 on: August 02, 2016, 08:24:08 PM »
Thanks for the input. I did unsrew the petcock. Maybe I messed something up.
Offline eigenvector
« Reply #3 on: August 03, 2016, 04:26:11 PM »
Ah, I just looked at the carb diagram for your model - it isn't the same carb  as the '84.  Sorry, no help to give you - it's a pretty standard choke carburetor.  Looks like you just didn't do a good enough job cleaning it.
Terrible advice I know, but cleaning that carb can be a real bugger.  I have a similar one on my CB750 Limited and it was a real pain to get cleaned.
Rob
1977 CB550K
1983 VF750S Sabre
Offline Honda550k
« Reply #4 on: August 03, 2016, 06:43:13 PM »
Compression? You need spark, fuel and compression for an engine to start.
Sent from my LG-H812 using Tapatalk
Offline purplechickenweasel
« Reply #5 on: August 03, 2016, 08:21:54 PM »
The carbs may be getting gas, but they may not be getting it to the motor.
With the air box off, you could spray a little starting fluid into each carb, and turn it over.
If it almost catches, then reclean the carbs, check the cross holes in the slow jets, and the main jet holders.
Pcw
Hazard is intent at high speed.
