Author Topic: Battery maybe  (Read 3107 times)
Offline PA7fifty4
Battery maybe
« on: August 03, 2016, 05:46:22 PM »
Ok guys I'm stuck. I just put new rings and valve seals in my 750. I have velocity stacks (let the hating begin) and an open exhaust. Main jet 120, slow 42, needle 2nd from the top. Bike started with no problems and ran before the new rings and seals but was fouling plugs and burning oil, thus necessitating the service recently performed. Any ways long story short the bike has been hard to start since the rebuild and when I would get it started it bogs and dies in gear. Now I found a wire had come loose from one of the coils so I blame the bog on that. Long story short I fixed that and still am having trouble starting it. My battery however took a beating with trying to start it. So I resorted to the kick start. My question is will the bike start with the kick start even with a weak battery?
Re: Battery maybe
« Reply #1 on: August 03, 2016, 06:38:25 PM »
Maybe, depending on how weak the battery is.
Offline PA7fifty4
Re: Battery maybe
« Reply #2 on: August 03, 2016, 06:46:04 PM »
Around 11 amps when I plugged it in
Re: Battery maybe
« Reply #3 on: August 03, 2016, 06:49:05 PM »
Huh? 11 amps when you plugged what in?
Re: Battery maybe
« Reply #4 on: August 03, 2016, 06:54:57 PM »
If you mean you are ramming 11 amps down the battery's throat with a big battery charger, shut the charger off RIGHT NOW!
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
Re: Battery maybe
« Reply #5 on: August 03, 2016, 06:55:59 PM »
What's the current adjustment of your air screws? And how old is the gasoline you're using?
I have a motorcycle problem.
Offline PA7fifty4
Re: Battery maybe
« Reply #6 on: August 04, 2016, 06:21:52 AM »
Haha yes I do mean volts not amps ::). Anyways gas is new and mixture screws are 1.5 out. Plugs were fouling before the rebuild. I tore the thing apart and there was a puddle of oil on top of piston 4. Plugs 2 and 3 were almost on the lean side with 120 mains. Once again I am running velocity stacks and an open exhaust. Hard to determine what the plugs are doing now considering I can't get it started and when I did have it started it would bog and die when I put it into gear. I have yet to ride it since replacing the rings and valve seals. It definitely needed valve seals and maybe rings. I had blue smoke and was burning a quart of oil every 50 miles and plugs 1 and 4 were always oil fouled. As for how it's running now I'm kinda clueless. I figured the bog was an indication of being too lean but as I stated I found a coil pack wire unplugged. Is this all making sense lol?
Offline PA7fifty4
Re: Battery maybe
« Reply #7 on: August 04, 2016, 06:22:40 AM »
I think the battery is shot tho. Had It charging all night and still wasn't charged
« Last Edit: August 04, 2016, 06:35:13 AM by PA7fifty4 »
Offline PA7fifty4
Re: Battery maybe
« Reply #8 on: August 04, 2016, 06:24:25 AM »
Oh wait you mentioned an " idle" plug chop?? How would I do that? Shouldn't I be worried about overheating??
« Last Edit: August 04, 2016, 06:35:01 AM by PA7fifty4 »
Offline PA7fifty4
Re: Battery maybe
« Reply #9 on: August 04, 2016, 08:06:23 AM »
Yes, you need to use a fan blowing air over the motor. Start the bike, let it idle for 3-4 minutes (with a fan) and then hit the kill switch. Extract plugs. That will help you adjust the idle circuit tuning.
One caveat, you do need to have your carbs vacuum synched for this, and if you can't get it to idle or stay running at 2,000 RPMs to synch, you need to remedy that first.
Thank you. I will try that. I have the carbs benched synced right now. It kept quiting on me when I tried to vacuum sync it. I have about a 1/8" gap under the slides right now for the bench sync. Is this too much or too little?
Offline PA7fifty4
Re: Battery maybe
« Reply #10 on: August 04, 2016, 05:32:36 PM »
Well guys your really gonna laugh :P I wasn't getting any fuel. I had my floats adjusted too low ::) :o :(
Offline NobleHops
Re: Battery maybe
« Reply #11 on: August 04, 2016, 09:52:53 PM »
Thanks for having the sack to "own it" brother. We have all been there, done that, one way or the other :-).
Offline PA7fifty4
Re: Battery maybe
« Reply #12 on: August 05, 2016, 05:59:09 AM »
Haha thanks for the help guys. Another lesson on why you never assume the obvious ;D
Offline NobleHops
Re: Battery maybe
« Reply #13 on: August 05, 2016, 06:38:07 AM »
If you want a good chuckle, check out my build thread and read my follies with troubleshooting my neutral light. :-)
Offline PA7fifty4
Re: Battery maybe
« Reply #14 on: August 05, 2016, 07:48:58 AM »
Will do
