Author Topic: Air bubble in gas line  (Read 1358 times)
Offline machacc
« on: August 04, 2016, 10:14:55 AM »
My 78 550 always seems to have an air bubble in the gas line between the carb and the petcock.  It does occasionally spit and I was wondering if this could cause that.  I have not had the petcock off yet for a cleaning.  Ron
Re: Air bubble in gas line
« Reply #1 on: August 04, 2016, 10:17:36 AM »
No biggie, really. If your fuel line is routed well, they should all rise to the petcock, and eventually escape into the tank.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #2 on: August 04, 2016, 11:15:27 AM »
It's all gravity fed, make sure there are no "up hills" in your fuel line routing. Also make sure the fuel line isn't too close to any hot spots on the motor as it might boil the gas before getting into the carb. I was having that issue but a reroute of the line fixed it. It's amazing how hot a bike can get when you sit in traffic.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline machacc
« Reply #3 on: August 04, 2016, 03:04:14 PM »
Thanks for the suggestions.  It does bother me so I better fiddle with it until it's unworkable and then put a new line on it.  Ron
Offline Gene
  • Chat enuf you too can be a
« Reply #4 on: August 04, 2016, 04:28:25 PM »
I usually have a little bubble on my 550 until I open the petcock . . . it's never been an issue.
*1973 CB750K3 (Bow)
Offline Mantree
« Reply #5 on: August 04, 2016, 04:48:06 PM »
I replace my fule lines from time to time any way might as well just get a role of it and replace it while you reroute it
Offline Steve F
« Reply #6 on: August 04, 2016, 06:24:02 PM »
I had opaque fuel lines and I never had an air bubble.... ;D
Offline Mantree
« Reply #7 on: August 04, 2016, 06:45:32 PM »
You should see what happens when you add a clear fuel filter
Sent from my SM-G900V using Tapatalk
« Reply #8 on: August 06, 2016, 01:04:25 PM »
 I replied that once and really PO'ed someone off. I agree, it doesn't seem to hurt anything, my brother has always ran his fuel lines down under the carbs through the filters and up into the carbs.  It flows just like the trap under your sink.
Offline machacc
« Reply #9 on: August 06, 2016, 07:55:42 PM »
I shortened the tube by 1/2" and that may have solved the air bubble issue.  I'm pulling the carb off again for another cleaning and adjusting.  It's getting a valve adj. and timing recheck also.  Ron
