Author Topic: CB750 custom wiring with M-unit questions  (Read 10753 times)
Offline slikwilli420
  • Master of Disaster
Re: CB750 custom wiring with M-unit questions
« Reply #25 on: September 07, 2016, 07:36:04 AM »
Cal, in the lower right, the box with the loops and two circles, that is the starter solenoid right? That and the M in the circle is the last part of the diagram I am trying to make sense of. Im guessing its the solenoid and starter motor.
« Reply #26 on: January 07, 2017, 01:17:19 PM »
Cal, now that I am wiring I have a few more questions. From the solenoid the Y/R goes to start out on the m unit. What do I do with the G/R wire that goes from the solenoid to the Silicon and to the clutch switch? Can I ditch that or should I just keep it?
Must RR also has three yellow, one red, and one green going to a plug. I assume I would sub my red wire in for the white on your diagram right? The other two wires coming from the RR are black and white. Assuming black goes to AUX out and white goes to the battery.
Lastly on the wiring for the m lock it shows a fuse between it and the battery. The instructions say a 1A fuse. Do you typically just use a blade fuse holder there?
