Author Topic: 550 Rocker swap, OK or not recommended?  (Read 743 times)
Offline WaxhawFive
  • 1975 CB550F Super Sport
« on: August 05, 2016, 05:12:03 AM »
I have a '77 CB550 loaded rocker cover to replace my worn '75 cover.  My plan was to tear-down and clean the new cover, inspect all 16 of the rockers (8 from my motor, and 8 from the new cover) and load the best 8 into the new cover.  But I'm asking if this is a good idea, to swap used rockers on old shafts, after they've been a mated pair for the last 40 years?  I don't know the mileage on the replacement parts, but two of the rockers were fairly tightly gummed onto the shafts requiring an overnight Kano Kroil soak to break free and rock freely.
So what od you think, should I keep the '77 rockers on their shafts, or is it OK to swap them around?
« Last Edit: August 05, 2016, 05:21:08 AM by WaxhawFive »
Offline jonda500
Re: 550 Rocker swap, OK or not recommended?
« Reply #1 on: August 05, 2016, 05:31:19 AM »
IIWM I would either replace all or none of the rockers so they will be mated with either the camshaft they are used to or the rocker shafts they are used to.
John
A starter clutch thread:
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=2q3l48els87va5ikedaq759jd0&/topic,60973.0.html
« Reply #2 on: August 05, 2016, 06:27:03 AM »
in a perfekt World  svap all to get it perfekt....
but in the real World..if there is any small diff..they vill be grindet togethe rin minuts..and one valve adj vil take care of it.
..its the lifters and the adjuster tap..vho goes on the valve..vho is critic for Wear..i vill go for the best looking parts..and just slam it together(if the parts is in spec)...its still a old engine both the donor and the fixed engine.(.it can only be almost as new)..so dont vaste a lot ekstra Money..it vill Work aut fine even mix the parts...iu have mixed parts in all my engines..and have no problems
id there is some vear on the cam
..grind  the surfase so the cam not have a grove..i have seen some have a small stripe at the autside of the cam areia..it need to be grindet dovn so the cam surface is good at the vhole areia the lifter can move on..
« Last Edit: August 05, 2016, 10:20:01 AM by strynboen »
i hate all this v-w.... vords
« Reply #3 on: August 05, 2016, 06:50:09 AM »
Go for it.
Use a liberal amount of assembly lube on the lobes and rocker faces.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #4 on: August 05, 2016, 07:54:07 PM »
CycleX does hardweld rockers on core exchange basis.  Really affordable.
Offline alacrity
  • Ride, Optimize, Repeat
« Reply #5 on: August 06, 2016, 12:37:30 AM »
So does Megacycle.
I recently restored and sold a 77 cb750f, and am nearly finished with a (former basket case) cb750k5.  This is a place to share, learn and enjoy.  I am grateful to and for 99+% of this site's membership.
Offline WaxhawFive
« Reply #6 on: August 08, 2016, 12:15:35 PM »
I ended up only swapping out one rocker, the other 7 were good in the new cover.  I put in a better 550 cam and installed the '77 rocker cover (used plenty assembly lube), set the lash, and all is good.  It's so much quieter, I guess I didn't realize how noisy my old ones were.  After a few trips I'll check the gap again just to see if anything has moved.
Thanks
