Author Topic: 81 650 camshaft  (Read 1021 times)
Offline Hawk213
81 650 camshaft
« on: August 11, 2016, 06:30:03 PM »
Hi fellas! So I'm trying to put camshaft back on and the issues I'm having is I don't see how to get the camshaft into the position on the mark, get the chain on sprocket and line up the sprocket bolt holes with the camshaft bolt holes. Doing all three of those seems impossible. It's like my chain is too tight or something. I've been working on it for a few hours. As I said, once the chain is on sprocket, there's no way to get it close enough to camshaft bolt holes to put bolt on. Once the chain is on the sprocket won't move up any. Any help?
Offline jonda500
Re: 81 650 camshaft
« Reply #1 on: August 12, 2016, 03:31:07 AM »
Not sure how the 650 tensioner is adjusted but it needs to be backed right off first, then put the chain around the sprocket and slip the sprocket into place on the camshaft last. Then pull up on the front side of the sprocket and check if the timing mark lines up - if it doesn't, slip the sprocket back off the camshaft to reposition the chain...
John
A starter clutch thread:
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: 81 650 camshaft
« Reply #2 on: August 13, 2016, 10:48:46 PM »
15deg after tdc there is a loose spot the chain comes on and off without a fuss.
Offline fastbroshi
  • Puppet
Re: 81 650 camshaft
« Reply #3 on: August 15, 2016, 08:03:34 PM »
  Pgs 31 and 89 of the 650 manual should help.  Look in the manuals section for that.  I haven't worked on my 650 yet, but looking at the manual I'm thinking it works the same way as the 550.  You should be able to loosen the locknut for the tensioner (while holding the tensioner stud with a screwdriver) and turn the tensioner opposite the direction it wants to return.  Don't go crazy, just give it some gentle pressure, and lock it down.
  Now go back to your cam chain and you should have just enough slack to get it all together.
Just call me Timmaaaaay!!!
