Author Topic: Where does this O-Ring go on my Keihin carb?  (Read 2034 times)
Offline jrrobertsjr
  • If you aren't scared, your not going fast enough.
« on: November 25, 2006, 04:50:57 PM »
Started rebuilding the carbs today.
One at a time to avoid confusion.
I got everything back together but had this o-ring left over out of my rebuild kit.
Any ideas where this goes? Does anybody have any pics.
I have searched the forums but haven't been able to find a topic on this one.
Thanks in advance,
Johnny
Offline Bob Wessner
  • "Carbs Suck!"
Re: Where does this O-Ring go on my Keihin carb?
« Reply #1 on: November 25, 2006, 04:53:01 PM »
What year/model bike is it?
Offline jrrobertsjr
« Reply #2 on: November 25, 2006, 04:59:13 PM »
They are from my CB750.
The bike is from a lot of years. 72 UK frame. 77 Rear end and a 74 front with a 78 motor.
I believe they are '75 carbs.
They are marked with a 7AII
To be clear, the rest of the parts in the kit looked good. They all matched the old parts. Just shinier.
I didn't see this o-ring when I took apart the carb and have checked the other carbs to see if I can find it but no luck.
Thanks.
« Last Edit: November 25, 2006, 05:09:43 PM by jrrobertsjr »
jdigga
« Reply #3 on: November 25, 2006, 05:16:13 PM »
I just got done cleaning my carbs and almost lost a tiny o-ring that goes in float bowl #2 for where the accelerator pump goes.
Offline scondon
  • Mmmm......tasty bugs
« Reply #4 on: November 25, 2006, 05:20:40 PM »
 Air/fuel mixture screw? C'mon, give us a hint as to what size o-ring you're talking about.
Offline kghost
« Reply #5 on: November 25, 2006, 05:56:05 PM »
A picture with something for scale would be nice...
Quarter or a penny or whatever coin of the realm
Stranger in a strange land
Offline jrrobertsjr
« Reply #6 on: November 25, 2006, 06:51:04 PM »
That is what happens when you post after the obligatory Saturday Night Margarita.
I thought I had already put this up.
Offline kghost
« Reply #7 on: November 25, 2006, 06:53:27 PM »
Definitely the idle air screw o- ring
Offline jrrobertsjr
« Reply #8 on: November 25, 2006, 07:05:12 PM »
OK... idle air screw o- ring...
Maiking progress.
Thanks KGhost. I probably should have given you a call first.
So if I am understanding this right, the idle screw is the one with the spring?
jsaab2748
« Reply #9 on: November 25, 2006, 07:58:26 PM »
If the carbs are '75 (k5), see if the o ring matches the one for the float bowl drain screw.
Offline jrrobertsjr
« Reply #10 on: November 25, 2006, 08:10:15 PM »
You might be right, jsaab2748.
Kghost and I kicked that around. I have a aluminum crush washer there on the four carbs that are on this rack.
We have been banging our heads on the workbench on this one...
I didn't see it when I took them apart. Kghost is going to check on some of his CBs later.
I will sleep on it. I do my best thinkin' when I am in the sack.
