Author Topic: Valve adjustment. Cam chain adjustment.  (Read 5124 times)
Re: Valve adjustment. Cam chain adjustment.
« Reply #25 on: August 22, 2016, 01:00:16 PM »
Ok so I just checked it with a voltage tester and the points open up and get electricity right when they are supposed to.  F 1.4 and F 2.3.  So everything seems good.  Is that it?
I've never done it that way, but I don't know why not. So yes, it should start right up.
The strobe lite would tell you if the advancer was acting up. Dragging, jumping around, etc. But a good ear and butt will tell you as well.
Offline cprisco13
« Reply #26 on: August 22, 2016, 01:46:10 PM »
Cool, thanks everyone for the help! I really appreciate it.  Now I can finally start my bike easier than before.  Still not running great but at least i know its not that.
Offline rickmoore24
  • Be led by your dreams, not pushed by your problems.
  • I <3 SOHC4's
    • Rosenbard Films
« Reply #27 on: August 22, 2016, 08:47:40 PM »
Awesome! So valves and the primary chain are situated, you've got the points sorted. Carburetor time? Clean, bench sync, vacuum sync and it should be purring.   :)
1972 CB750 K2 (Daily Runner)
1972 CB750 K2 (Sold)
1973 CB750 K3 (Hardtail 836cc)
1998 CBR F3 - R.I.P., went down on the 101 in Calabasas, Ca.
1995 EG6
Offline DaveBarbier
« Reply #28 on: August 23, 2016, 05:40:17 AM »
For the timing strobe, positive clamp on positive at battery, negative clamp on ground or negative at battery. The other weird clamp is an inductive pickup. It senses the spark pulse through the spark plug wires by way of magic. With your bike idling and the special clamp over either the #3 or #4 plug wire, point the gun at the timing window in the points plate and pull the trigger. You should see the F mark lined up with the witness mark on the case. If your special magic clamp is on the #3 wire then you'll see the marks for the 2-3 cylinders. If the clamp is on the #4 wire you'll see the 1-4 cylinder marks.
Then, rev the motor to about 3k rpm and you'll watch the marks move counter clockwise. Then the advance marks should appear and match the witness mark. There are two advance marks, just get them to straddle the witness mark on the case. Do this for both 1-4 and 2-3.
The advance setting is more important than idle setting. So if the advance is good but the idle F Mark doesn't line up exactly, no worries. But with properly gapped TEC or Nippon Denso points and plate they should be good.
Search YouTube for "timing strobe" and you'll find videos.
