Author Topic: Quick question about cam case..  (Read 788 times)
Offline sweatshirtolympics
« on: August 19, 2016, 04:30:32 PM »
Do the valves have to come out to remove the cam case and also what grit sand paper is safe for cleaning aluminum?
Thanks guys ^^
Re: Quick question about cam case..
« Reply #1 on: August 19, 2016, 04:41:18 PM »
And also a quick pic of the setup for your viewing pleasure.
Offline Thekramer666
« Reply #2 on: August 19, 2016, 04:54:01 PM »
If your reffing to cleaning the seal surface I always use fine Scotch Brite pads
Please check your messages & follow up on your posts!!
76' CB550F SS
« Reply #3 on: August 19, 2016, 05:22:03 PM »
Yes, perfect thank you
« Reply #4 on: August 19, 2016, 05:30:36 PM »
But no as far as I can tell they don't need to be removed..
« Reply #5 on: August 20, 2016, 03:58:06 AM »
There is no grit of sandpaper(or emery/wet and dry) safe for cleaning gasket surfaces as the grit can get into the motor and destry all the bearings
« Reply #6 on: August 20, 2016, 09:10:58 AM »
Awh yeeeah, good thing a full motor tear down is in the works  ::)
« Reply #7 on: August 20, 2016, 11:05:59 AM »
Cellulose thinners or 2Gun Wash" should remove all traces of gasket, goo or otherwise, along with GENTLE scraping or scotchbrite----THEN a really good clean out
« Reply #8 on: August 20, 2016, 12:37:47 PM »
Awesome Bryan thanks, got the head off last night, this thing had no head gasket with pools of oil at the top of all 4 Pistons lol.
« Reply #9 on: August 20, 2016, 02:13:12 PM »
The only difference between a 500 and 550 gasket kit is the clutch cover gasket and the only difference in the seal kit is the 500 has a push rod seal where the 550 has a blanking plug.
If you are tearing it all the way down fit a new primary chain---costly but there is no tensioner and it can wear through the main oil galleries when worn.
Did it actually run with no head gasket?
