Author Topic: RPM surge  (Read 1653 times)
Offline Broseph
RPM surge
« on: August 22, 2016, 07:47:38 AM »
Hey there,
Recently my bikes rpm has been surging while driving. It revs up while speed remains the same and then drops back down. I have cleaned carbs and put them back on only to still have this happen. I have checked over carb boots and there is no cracks. Boots are only a couple months old on bike. Tightened boot clamps but still same issue. I am wondering where else I should look. Timing?
1974 cb750 k4
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
Re: RPM surge
« Reply #1 on: August 22, 2016, 08:05:44 AM »
Clutch
--Evan
1975 CB750K "Rhonda"
Offline 540nova
Re: RPM surge
« Reply #2 on: August 22, 2016, 08:47:36 AM »
+1 clutch
1974 CB450, 2006 CBR1000RR
Offline Broseph
Re: RPM surge
« Reply #3 on: August 22, 2016, 03:22:17 PM »
Thanks for the responses. If I am to replace clutch plates and springs is there an ideal brand or supplier?I am not racing the bike by any means. Thanks
1974 cb750 k4
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
Re: RPM surge
« Reply #4 on: August 22, 2016, 03:37:50 PM »
Adjustment correct?
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline USMC5811
Re: RPM surge
« Reply #5 on: August 22, 2016, 04:17:28 PM »
I was also wondering - does anybody sell whole rebuild kits, or does one have to buy "6 of everything" piece by piece?
Offline Broseph
Re: RPM surge
« Reply #6 on: August 22, 2016, 04:26:21 PM »
By adjustment you mean clutch cable? I'll have to check it next time I'm at the garage. How much slack should there be?
1974 cb750 k4
Offline martin99
  • UK Based, Non-
Re: RPM surge
« Reply #7 on: August 22, 2016, 04:44:38 PM »
You'll need to remove the cover.
Slacken off completely the adjustment at both ends of the cable, so the cable is not under any tension.
Loosen the locknut under the clutch cover. Turn the adjusting screw out a turn or two(so it is free), then turn back in clockwise until you can just feel the pressure of it getting tighter. Back it off 1/4 turn, and holding it in position tighten the locknut.
From the clutch cover end, take up the adjustment on the cable until you have about 3/8" to 1/2" freeplay at the lever - meaning you can pull the lever in by that amount before any resistance is felt.
Job done. Use the adjuster at the lever for fine tuning if needed.
Worth checking before you shell out for a new clutch.
Build threads:
1977 CB750 F2
Offline USMC5811
Re: RPM surge
« Reply #8 on: August 22, 2016, 08:06:46 PM »
I've got zero free play and a new clutch cable ready to install.
Guess I know what will be tomorrow's project...
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: RPM surge
« Reply #9 on: August 22, 2016, 08:58:29 PM »
Zero free play is bad juju, clutch lever needs some wiggle, and the notches on the clutch case and armature need to be aligned.
Re: RPM surge
« Reply #10 on: August 23, 2016, 10:39:56 AM »
My new motionpro clutch cable broke and stranded me w/ less than 500 miles on it.
My original clutch cable from 1978 went back on and is still doing its job  ::)
