Author Topic: Jakal cb550 project  (Read 39983 times)
Offline Darren Jakal
Jakal cb550 project
« on: August 22, 2016, 08:39:46 AM »
Hi Everyone,
I just joined this site as I've recently picked up an abused and abandoned 78 cb550 that I am going to take on as a low budget, slightly modified commuter.
This site has already been very useful in understanding what I am dealing with, so I want to thank all contributors for their efforts.
Darren Jakal
« Last Edit: January 24, 2017, 09:13:43 PM by Darren Jakal »
Re: Jakal cb550 project
« Reply #1 on: August 22, 2016, 09:22:14 AM »
I’ve seen this bike parked up against a fence in someone’s backyard since I moved into this neighbourhood 3 years ago. About 3 weeks ago I was riding down the alley when I saw two people talking at the garage where the bike was located. I asked about it and if it was for sale and long story short was pushing it back to my place the next day.
Ugo, the old guy who sold it to me, didn’t know much about it. He was a bike guy with a garage full of big cruisers and he said someone dropped it off at his place roughly 20 years ago. He knew that it was bought at an auction in a small town north of here, but other than that not much. He did mention that something was up with “the chain”.
So, I began to take it apart to get to know what I was getting into. One of the first things I noticed was that the rear tire did not seem centred on the bike. I started to think that it might have been in a wreck and started to look for impact sites or other signs of a crash (the front fender has a good dent directly below the headset and I was wondering how hard would this be to do, I mean can these things dive so deep that the fender can hit the headset?).
This site has been very useful in answering some questions and I was soon running string lines to try and understand what was going on. First thing I did was pull the rear wheel and swap the spacers on the axle. This seemed to move the tire in the right direction and line up the chain much better (remember Ugo told me about the chain). I thought I had it all centred but something was still not right, so I took off the wheel again and put it back on without the spacers. I aligned everything again and thought I had it centred, but the sprockets didn’t line up with where I had the wheel. I redid my work and had the wheel centred and the sprockets lined up and then looked again at the spacers (there are three with one that that can only fit into the chain side and two others, a long and short one). Where the wheel was on the axle was pretty much exactly the length of the spacers so I put them back in and everything aligned with centre and the sprockets lined up.
Then I took off the front fender and realized that the front wheel wasn’t centred (found some info from Hondaman about this so I’m not worried). Anyway, I have been stringing line and measuring things (like distance between centres of the swing arm pivot and rear axle when pushed up tight in the drop outs), and for the most part things are looking OK except for the position of the rear tire in respect to the rear of the bike and the axle location in respect to the alignment marks stamped on the drop outs. The rear wheel really looks (and depending on where I measure) to be about 15 millimetres further from the chain side when compared to the shock mount locations and the very rear end of the frame.
So, is this normal? Is this for making more room for the chain or am I being deceived.
I guess I should post these questions in the SOHC/ 4 Bikes section.
Cheers, Darren
« Reply #2 on: August 22, 2016, 09:34:33 AM »
Welcome, Darren. Cant help, never touched 550. ;)
Offline calj737
  • I refuse...
« Reply #3 on: August 22, 2016, 10:17:24 AM »
Its quite common that folks install the rear wheel spacers incorrectly. Also, there is a difference between the F and K model 550 rear wheel, backing plate, and spacers. The important point is to align the sprockets, and insure the hub is centered from there. If you need different sized spacers to achieve it, either use a lathe and turn some from aluminum, or stainless.
Of course, you also need to confirm the wheel bearings are properly installed...
« Reply #4 on: August 22, 2016, 11:34:43 AM »
Hey, thanks for the welcome and replies. I'll make sure the bearings are right and I'm taking my time to understand what will need to be done before I jump to far into it (I've learned patience in my old age).
It's like an archeological dig, but it's dismantling a bike to discover its past. I can only wonder what has been done to it over the past 38 years and as I take it apart I can start to put a picture together.
It was bought at auction in the early 90's. Was it a police auction and it was stolen, I don't know. I know someone had the rear wheel off at one time and that there was probably something going on with the electrical (all kinds of questionable repairs with stator and cover missing). But I kind of think it's mainly just the one bike and no one has really done any serious mechanical work or alterations (so probably not a mismatched swing arm).
I also think it's very low milage and the use it's seen has been short term abuse (although I can't find any frame dings or dents the front fender and right side engine case cover has some dings). The drum brake pads are only lightly worn and and the foot pegs look almost new. All the fins are intact and because it's Canada it was at most driven for 4 months a year for a max of maybe 12 years or so (and this would be a lot of riding for that time period (78 to say 90) in these parts).
Anyway I want to reuse as much of it as possible, but spend some time/money on steering bearings upgrades and maybe a Hondaman swingarm set-up (although I work in a fabrication shop and could probably make brass bushings I don't have the experience or knowledge of WHAT to make for the swingarm that someone like Hondaman would know - I don't mind paying for knowledge and experience and it seems a bargain for what you get).
I had apart the carbs to clean and refurbish and realized that the choke felts were in pretty rough shape. This gave me a chance to drop by the local old motorcycle shop in town and get to see another side of life (this is my first bike project). Seems like these felts are hard to come by and they were a bit astonished that I had pulled the carbs apart. They just strip and ultrasonic clean, but where's the fun in that. Anyway, the old carbs that were in the used pile were as bad as mine, so I got to thinking about alternatives and found that brass grommets can be refitted to make a not bad seal. I put a light spring between the carbs to keep them in position and they don't interfere with the choke movement. Not sure how well they work and if this is even a good idea, but we'll see.
Thanks again, Darren
« Reply #5 on: August 25, 2016, 05:11:54 PM »
Cleaned up the carbs, reassembled with backyard choke felt upgrades.
I'm impressed with the builds I see on this site, beautiful rides. Mine is not going to impress anyone. A budget return to the road of a bike I've always wanted.
I'm going to pull the frame off the engine soon (the lay it in the grass method) and I'm adapting an engine stand (thanks to everyone for their ideas shared here).
I've found a post the provides the distance between centres for the rear motor mounts of the 750 and was wondering if anyone had an accurate number for the 550?
It looks like 195 mm to me but that's measuring withe the engine in the bike and the bike behind the garage in an awkward place (once I get the engine out I can get it all in the garage).
Thanks for any help! Darren
« Reply #6 on: August 26, 2016, 03:55:39 PM »
Hi everyone,
Excited to see other 550 builds on here. I have the engine out and a rolling frame in the garage. I'll make brackets to fit the engine stand soon.
The rear wheel has been really bugging me and after much messing around and searching this site I've concluded that the rear hub (probably the whole wheel really) is from another year 550 (mine is 78K). Anyone tell what it is and what spacer dimensions would work? I can measure pretty accurately, but if there is some factory # that would set it up right I would appreciate knowing it.
Cheers, Darren
Offline Scott S
« Reply #7 on: August 27, 2016, 03:57:52 AM »
 That does look like the earlier backing plate. It shouldn't be a problem running that wheel/brake combo as long as you have the correct axle spacers.
 I have a nice set of side covers that'll fit that bike (I also have a nice set of 4-4 pipes, but don't know how in the world I'd ship something like that).
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Chappy
« Reply #8 on: August 27, 2016, 04:18:06 AM »
Nice work on the carbs.
« Reply #9 on: August 27, 2016, 03:33:38 PM »
Thanks for the offer Scott. Not sure what the final plan is for this bike. All I know is that I will keep as much of the bike stock if it's within tolerance. I'll spend the budget on handling (taper bearing for the triple and brass swing arm bushings, suspension upgrades, brakes, tires and then aesthetics). This is a low budget revival and I'll do all the work myself so I'm giving myself plenty of time.
By stringing the bike and measuring various points on the frame I figured out where I would put the rear wheel and then measured with some inside calipers to within a hair of 44 mm .
" 'K' models use a 44mm collar on the brake side and a 31mm collar on the sprocket side"
I read the above in a post on rear spacers for the 550 (from Jonda500) so I'll make a 44 and 31 and see if that works.
And thanks for the compliment on the carbs Chappy. They turned out really well and I've reused pretty much everything except some orings. I'll bench test for leaks to see if that's good enough.
« Reply #10 on: August 28, 2016, 10:58:51 AM »
Finished the engine stand using some aluminum left over from another project and a base unit from princess auto. I looked at lots of idea from here and want to thank those contributes for their efforts.
I decided to try and keep the brackets tight to the inside to allow lots of side access and although I'm not planning to crack the case I left myself the option of cradling the case using some solid aluminum 1" extension bars that I can make attachments for depending on the job. I used some solid 1"x 1.5" aluminum to make uprights that have 4 different places to put the extension bars. I'm thinking I could also make tool trays or part holders that could bolt or clamp to the uprights.
Anyway, engine is on the stand and the bike is in the garage.
Anyone know what these BBBBBB stamps could mean? On the lower half or the case on the back.
Cheers, Darren
« Reply #11 on: August 28, 2016, 11:16:04 AM »
Cheers, Darren
Bearing sizes in the crank case.
« Reply #12 on: August 28, 2016, 02:10:19 PM »
[/quote]
[/quote]
Thanks Fan!
« Reply #13 on: August 30, 2016, 06:07:34 PM »
I've been pealing back the layers that make up the history of this bike and by judging by what I'm seeing there may be as little as 5-10k km on this thing.
This can be the story for a Canadian prairie bike. A few rides at the acreage each summer for some lucky couple (the two tier seat with backrest and sissy bar give it away) and then stolen one drunken autumn party by a townie and wrecked (the ding in the tank the new paint is trying to hide, the beat out timing cover, broken bolt boss and faint graze on some fins, combined with the ding on the fender right below the headset).
Sold at auction because the bike was (maybe) 12 years old and why not take the insurance money since they didn't ride much anyway. A haft hearted attempt at a resurrection (different rear wheel, missing generator parts and cover) and then left for dead in a back alley until someone comes along to do the right thing.
Anyway I've been preparing for the "swing arm bushings" and I know that they need to be replaced and that I might need someone like Hondaman if they are in rough shape but the thing is they are tighter than... tight (that rear is tight, no play but rotation around the axis but I don't know the state of the original bushings as I'm not digging them out until I'm ready to put something in).
So, for someone like me that wants to do a bike once and ride it forever what do you do?
I'm thinking about nickel plating the swing arm, but when? Before or after doing the bushings? Do I plate and then make custom bushings to fit inside? Or do you cover the bearing surfaces, plate and then insert bushings?
I've plated before and have made bushings before, but I've never plated something that then needed bushings (same with the shock mount bushings that I hear can be a disaster).
Anyway, thanks for any help, this place is great!
Darren
Offline calj737
  • I refuse...
« Reply #14 on: August 30, 2016, 06:31:17 PM »
If the swing am is tight, service it with fresh grease to loosen it up so you can service it.
Nickel plating is cool, but not terribly durable in certain climates, so give that a thorough think. If you do opt to plate it, do so, then do the bushings. You can get bronze bushings and turn them down if need be to fit.
« Reply #15 on: August 30, 2016, 09:00:58 PM »
Hey calj737,
Swing arm moves well and is tight in that I can't get any unwanted motion. I pumped it full of grease and it would be ridable, but I now know the original bushings need to go.
I want the toughest finish on the underside I can get. It's Canada, so it will be ridden when it's nice, because when it's not nice you don't ride motorbikes. What do you suggest for best finish for long term?
Any opinion on where to get good bushings to turn down? I can buy oilite, but it's not cheap so a good bushing for the right price would be great. I wonder if Hondaman would sell just bushings (oversized to turn down). I should ask him.
Anyway thanks again for your help!
Darren
« Reply #16 on: August 31, 2016, 03:56:16 AM »
Did you check kenosha_kid on ebay for bushings?
Bushings can be purchased from McMasterCarr too, if you are able to adapt them for your need.
Offline calj737
  • I refuse...
« Reply #17 on: August 31, 2016, 05:13:54 AM »
Powder coat is probably the most durable finish.
If your swing arm bushings don't have any slop in them, why change them? Its fine to do, new Oillite (from kenosha_kid) are pretty inexpensive investment.
« Reply #18 on: August 31, 2016, 06:45:14 AM »
Thanks for replies calj and 70CB750,
My understanding is that the bushings that are in there are made of powdered steel (or something like that) and that eventually these bushings will be trouble as two similar metals are not appropriate for wearing surfaces (I don't want to redo a thing if I can).
I can turn down an existing bushing but in my mind (I'm NOT a machinist but have an engine lathe with digital readout) making a new one from stock is almost easier when it comes to chucking properly. Inside reaming or boring would be simple but turning the outside of a top hat bushing makes it a bit more difficult (for me anyway, unless there are tricks and in this day and age with google I may find a way, like making a sleeve to keep the bushing straight and turning on centre).
BTW what is the powdercoat method? Powdercoat and then install bushing to fit the powdercoat or do you take it back to the original surface (or protect it from being powdercoated in the first place)? What about the shock mount bushings? They sound worse.
Thanks again for any help!
Darren
Offline calj737
  • I refuse...
« Reply #19 on: August 31, 2016, 09:51:15 AM »
Powder coat, then clean the hole interior surface as needed to fit the bushing. The shock lower mount is a clevis type.
To turn the bushing on a lathe, ream the hole, and turn down the outside diameter of the bushing that fits into the swing arm. Once you have the full length of the turned down surface, reverse the part in the lathe. Turn down the length of the OD of the top hat. Then use a parting tool and cut it off. Simple.
« Reply #20 on: August 31, 2016, 04:06:00 PM »
Thanks for chiming in calj,
Yea making a bushing is not hard, as I mentioned I've made them before. What I've not done and what I thought would be more difficult is to turn down the OD of an existing top hat bushing. How do you chuck it without making a jig.
I figure I could make an inner sleeve with a lip that the bushing goes over that is then sandwiched between an outer sleeve (a blind hole sleeve) that is held in place with a centre in the tailstock. So making a new one is about as easy as turning down an existing one as you have a lot more stock to chuck when making a new one and you don't have to make a jig.
Anyway, I spoke with platers and powdercoaters today and was told by both that they can plug anything that needs to remain in tolerance, so I may just buy some existing bushings mentioned here (although it doesn't sound like he ships to Canada).
Cheers, Darren
Offline calj737
  • I refuse...
« Reply #21 on: August 31, 2016, 06:01:50 PM »
Chuck it up, center it, and get to cutting. Maybe our lathes are of different capabilities, but mine is pretty easy to center, tool, remove, then install back into location. I reverse parts all the time and don't have issues. If you want to reduce the OD of the insert end, grip it by the top hat lip and turn away. Just turn it slowly.
« Reply #22 on: September 01, 2016, 06:05:38 PM »
With the engine up I'm going over it to se what needs to be done.
The ding on the points cover was bad enough to break a bolt boss. Not a priority as there are enough threads to suck it tight with a slightly longer bolt that aligns deeper in the case.
With the different rear wheel and wrong spacers my guess is that when the chain came off and gored the case is when the bike was parked for good.
I was looking online for some airbox parts and came across my identical carbs for $40 CDN pesos. So I grabbed them (is this going to become a problem, we'll see). I still can't believe in what good shape all the rubber and plastic is in.
It's actually still soft.
Later, Darren
Offline calj737
  • I refuse...
« Reply #23 on: September 02, 2016, 04:42:31 AM »
Since that points cover took such a bad beating to break the case, you need to inspect carefully the timing shaft for any wobble or runout deviance. If not, your timing will be wonky forever and you'll be chasing your tail endlessly.
Take note of the position of the cam beneath the ignition plate. It can be installed 180* out upon reassembly. There's a small mark on it for alignment.
« Reply #24 on: September 02, 2016, 07:22:07 AM »
Thanks man! Will do.
