I’m hoping to put it all together for spring and I have a few items I need to confirm, decide or discover. Such as the much loved Lubrication Items. I'll make this a record of what I'm discovering in my search to help me find it again again and to share with anyone with an interest.
Lube clutch parts?
From HondaMan in this thread:
http://forums.sohc4.net/index.php?topic=7260.0“First word: GREASE! The clutch lifters on these bikes wear more because there is much more shifting going on. Grease those lifters!”
dr. destructo says:
“whats this talk of grease fittings for the clutch lifter? I cant find a grease fitting anywhere, and my clymer manual never mentions anything about zerk fittings either. If my bike has zerk fittings, I'd love the use them!”
TO this TwoTired responds:
“It's only the 500 that has the clutch actuator grease fitting.”
Ok, so for my 78 550k the oil in the engine /trans lubricates the clutch. Correct?
Points cam lube? Lube the advancer weights where they pivot?
From HondaMan:
http://forums.sohc4.net/index.php?topic=138514.0“If the advancer weights are working OK, they probably don't need help. When I have them out, though (like engine rebuilds), I soak the whole thing in solvent to strip off all old goo, then dab a small bit of grease on the weight pivots and inside the points cam. High temp grease is good. There used to be "points grease" for the rubbing blocks, I am sad to say I used the last of mine in 2005, though. It is a yellow petroleum-based grease that is like wax, and has a great affinity for phenolic points feet. It soaks into the material and burnishes them in like glass.
MRieck suggests (same thread as adove): Mallory 26015 Distributor Grease
Also on this topic:
http://forums.sohc4.net/index.php?topic=149140.0Lube the cables (clutch, speedo, tach, throttle) ?
From bryanj:
http://forums.sohc4.net/index.php?topic=27530.0“NO NEVER EVER on OEM cables maybe yes on aftermarket ones.
You are correct the originals are nylon lined outerers withrubber(ish) coated wire and lube swells both till they bind. This INCLUDES WD 40 or similar as ALL the air arsole canes are Butane propelled and it the petroleum bits that cause the problem”
TwoTired (same thread as above):
I have several bikes that I switch between. If a cable on one seems more draggy than the others, it gets a bath in dri-slide. There is some interaction with wet weather, too. Bikes ridden in the rain seem to need a more frequent dose. I'd estimate every 2-3 years they get serviced. But, if a bike was left out in the elements, I expect it would need more frequent attention. I should note that our weather patterns are quite mild. We average 14.4 inches of rain per year. And we can go 6 months with no rain at all. Then there is the bike wash routine as a factor.
To keep any rust at bay I sometimes add a drop or three of Dillon Blue Magic, which I got from Dillon Precision. I think it is a synthetic oil with "teflium" in it, what ever that is. It says Flouropolymer on the label. Sadly, it is no longer in their catalog. But, they now sell this which looks interesting. I might try it if my current 1oz, bottle ever runs out.
http://www.dillonprecision.com/#/content/p/9/pid/24848/catid/16/Snake_Oil_0_5_oz__BottleLube the caliper assembly?
Good stuff from TwoTired again:
http://forums.sohc4.net/index.php/topic,56544.0.htmlThis thread has gotten very confused. Lets' review.
There are four products needed to restore a caliper.
1. Brake cleaner
2. Brake parts assembly lube for the caliper seal only.
3. Dow corning High vacuum grease.
4. Brake fluid
Each has it own specific application and needs for the task to be performed.
#1 is used to get everything clean. (given the confusion, it had to be said)
#2 is used ONLY on the seal and must be compatible with #4, as some of it will invade the brake fluid chamber.
#3 is NOT used on the seal, as that would put silicone inside the brake fluid chamber. This is a bad thing as the compounds are incompatible. It is used behind the brake pads and a thin coat is used on the parts of the calipers and piston that are exposed to the elements and subject to water ingression. The Dow Grease will not mix with ANYTHING. It is a simple barrier with the very important property that it will NOT melt when the parts get hot and then run/creep into the brake pad friction material and provide lubrication between pad and disk rotor.
#4 is what makes the hydraulic part of the brake function. (I hope that part is clear.)
If anyone has anything to add or clarify on any of these lubrication matters I’d love to hear it ! I'll update as need be.
Cheers, dj
edit to add: anti-seize:
http://forums.sohc4.net/index.php?topic=117474.0
