Thanks both, I was on YouTube looking at the keyless setup last night with the additional reed key. Very nice. I take it the m-swicth is going to be used for the new tacho I will ultimately be buying..
Question: The bikes engine is currently seized, I have removed spark plugs, applied penetrating oil, let soak and rocked bike (repeat). The secondary engine I have is not seized, I can turn it using the kickstarter (although I don't know if it actually 'runs'). I am at a crossroads.
a: Should I just swap out engines now and get the 2nd one running - before I start chopping tabs and welding in seat hoops etc.
b: Persevere with seized engine.
c: Remove seized engine, detab, weld etc and then install 2nd engine.
d: Other.
