Author Topic: bottom end knock , metal shavings in oil HELP  (Read 3821 times)
Offline hoekakes
« on: August 27, 2016, 07:10:13 PM »
alright so i recently traded my truck for a motorcycle ..now that ive got the motorcycle im sure the carbs are out of adjustment the guy said he cleaned them and couldnt get the rubber boots seated right .. anyway i got it started but theres a knocking coming from the lower end while the engines cold .. it almost goes away completely when its warmed up then i went to change the oil and found a bunch of metal shavings .. how much trouble am i in right now ?
Offline Scott S
Re: bottom end knock , metal shavings in oil HELP
« Reply #1 on: August 28, 2016, 04:09:58 AM »
 First of all, what bike? Model and year, please. You posted in the Hondamatic section....do you have the semi automatic CB750?
 The bottom end knock could be carbs out of sync, and most likely is, since you say someone has been working on them.
 Do the 3K mile tune up and vacuum sync the carbs.
 Pics of the shavings would be helpful. But start with the tune up and carb sync.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline hoekakes
« Reply #2 on: August 28, 2016, 09:25:58 AM »
ive got a 1977 cb750a , the shavings look like glitter , i cant get a good picture right now since its sitting at my friends house
« Reply #3 on: August 28, 2016, 01:05:58 PM »
Sounds like it needs a new bottom end,as in crank and bearings.
Offline hoekakes
« Reply #4 on: August 28, 2016, 06:16:40 PM »
exactly what i was afraid of , does anyone buy bikes with problems like that .. its a complete bike with vetter fairing and even the original owners manual
« Reply #5 on: August 28, 2016, 06:39:39 PM »
Do yo want to pull the motor and fix it..afew hundred for bearing sand gaskets, may need a used crank.. You can usually pick up a wreck for cheap, swap motors.
Offline hoekakes
« Reply #6 on: August 28, 2016, 06:59:54 PM »
i did find a crank with bearings and rods on ebay for 120 but im not sure im capable of tearing something like this down and gettingbit back together right
Online scottly
« Reply #7 on: August 28, 2016, 07:25:38 PM »
Just how much "glitter"? Was the glitter in the oil filter housing, the oil pan, or the pan you drained the oil into? Does the glitter stick to a magnet? Does the oil pressure warning light come on when you first turn the key on, but go out once the motor is running?
Offline hoekakes
« Reply #8 on: August 28, 2016, 07:46:42 PM »
i dont have any of the oil at hand right now but there was a good amount that settled to the bottom of the pan i drained it into, oil light does come on until i turn it over which i assumed was normal
Online scottly
« Reply #9 on: August 28, 2016, 08:23:05 PM »
Yes, it's normal for the light to go out once the motor is turning. If it stayed on with the motor running, then a lack of pressure from a worn bottom end might be the cause, but since the light goes out, I wouldn't be too quick to tear the motor apart just yet. ;)
Offline hoekakes
« Reply #10 on: August 28, 2016, 08:36:48 PM »
weve got the carbs off it right now and slide number 2 is open further than the other 3 and the butterfly valve doesnt close as far as the other 3 .. im not seeing any thing that adjusts that on these carbs lol im clueless but want this bike to run without issues by next summer
Offline stikman
  • Bit of an
« Reply #11 on: December 10, 2016, 02:02:55 PM »
+1.  These motors are notorious for a bottom end knocking sound at low idle with carbs out of sync.  Certainly worth trying that first.
1977 CB750A "High Horse": 836cc, mild porting, custom cam, K5 roundtops, v-stacks...
1973 CB750K D5 plunger frame chopper currently building..
Offline Randy Nevrotski
  • Randy
  • ITS AUTO-MAD-TIC
« Reply #12 on: November 29, 2019, 06:44:24 PM »
I read your post what did you ever end up finding out the problem . what did you do
1976 CB750A & Other bikes 1980 KZ 650 cafe racer  81 CM400A 82 GS450 79 KZ650 84 NIGHTHAWK 700 77 KZ650 CAFE  87 ZX750R NINJA 2001 KATANA 600 1983 GPz 750 1980 CB750 CUSTOM Past bikes 1974 suzuki GT750 TRIPLE Care Free Custom chopper 117 motor 95 Honda XR650L Dual Sport 87 ZX600R NINJA Honda CB550FOUR 87 Yamaha 225 trike honda 250R trike RM80 HONDA TRAIL CT70
Offline jukku
  • Happy with my Hondamatic
« Reply #13 on: December 01, 2019, 12:51:32 AM »
