Author Topic: 1972 CB350f Fork Shrouds / Covers  (Read 1274 times)
Offline H2Eric
« on: August 29, 2016, 10:40:26 AM »
I need some help here. Does anyone know how to remove the chrome fork shrouds / covers without damaging them? Then once removed is it possible to have them re-chromed without damaging the plastic/nylon pips?
Thanks
Eric
« Last Edit: August 29, 2016, 10:52:19 AM by H2Eric »
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
http://forums.sohc4.net/index.php/topic,94588.0.html
Growing old is mandatory, growing up is optional.
Offline chrisbc55
Re: 1972 CB350f Fork Shrouds / Covers
« Reply #1 on: August 31, 2016, 02:34:27 AM »
Yes they definitely come off. I've removed a few of them.
Firstly spray heaps of penetrating oil inside (CRC or similar) as they will be stuck at the bottom. Leave overnight.
Next with a soft rubber mallet or the soft rubber handle of a hammer (don't use the hammer end!!) gently tap in an upward motion ( ie in the direction they will be coming off) and only tapping at the bottom joint area as they are supported at that point. Move around so it releases evenly and once starting to move just wobble back and fowards gently by hand until off.
Yes once off they can be rechromed but they are light metal and the polisher has to be gentle
Hope that helps
Chris
Offline AshimotoK0
  • CB400/4, 69 CB750K0, '69 CB250SS, CB350K1 CB500K0
« Reply #2 on: August 31, 2016, 04:22:51 AM »
On my CB350K4 twin  ones ( very similar) I wrapped a single turn of inner tube rubber around them and then gently clamped on two  hose clips with the clamp bits 180 degrees opposed. Then tap on the clamp bits gently and they should ease off without distortion or chrome damage.
“Alright friends, you have seen the heavy groups, now you will see morning maniac music. Believe me, yeah. It’s a new dawn.”
Offline H2Eric
« Reply #3 on: August 31, 2016, 01:41:36 PM »
Thanks guys, much appreciated.
Best regards
Eric
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
Offline H2Eric
« Reply #4 on: November 10, 2016, 09:16:26 AM »
Having got the shrouds off and without damage I might add. Thanks for the tip Ash. The next question is re-chroming. I've them to a chap in Derby, but he's very reluctant to have a go at them as the shrouds are so thin. Has anyone had a pair done and by who?
Eric
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
