Author Topic: F c m wheels  (Read 1262 times)
Offline monkeyrocco
F c m wheels
« on: August 30, 2016, 03:47:55 AM »
Hi all first many thanks to those of you that took the time to help with my boots post, so it looks like I have a 350 four with a bimota tank and seat in fibreglass (which  fits perfectly into my 750). Still confused about the wheels though five spoke mags with f c m on them twin disc front and rear disc with Delta Freni calliper, any info anyone? Thanks again
have fun ride safe
Offline monkeyrocco
Re: F c m wheels
« Reply #1 on: August 30, 2016, 03:49:57 AM »
Boots w t f is boots meant last :-[ :-[
have fun ride safe
Offline Bankerdanny
  • Endeavor to persevere
Re: F c m wheels
« Reply #2 on: August 30, 2016, 10:37:22 AM »
You will have better luck getting useful replies if you provide more pictures of the wheels and the markings.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: F c m wheels
« Reply #3 on: August 30, 2016, 10:57:27 AM »
What you're not keeping the 350 in one piece?
How am I supposed to give it a kosher funeral?
Offline monkeyrocco
Re: F c m wheels
« Reply #4 on: September 01, 2016, 11:35:58 AM »
OK stupid of me not to upload photos. Don't worry the 350 will be intact for its funeral just tried the tank on the 750 just because i had to or I wouldn't be able to sleep  , as for funeral arrangements I will be having the 350 ridden over by young fellow from the lower classes a vagabond whom I have no further use for in fact keep him he goes by the name of
have fun ride safe
  • Holy Cow! I'm a
Re: F c m wheels
« Reply #5 on: September 01, 2016, 12:16:05 PM »
My aging father will appreciate the labor of such a lowly serf.  I will waive the customary fees in light of such a donation.
Re: F c m wheels
« Reply #6 on: September 01, 2016, 06:27:30 PM »
The front axle isn't installed properly: the "head" of the axle on the right side should be flush with the clamp on the bottom of the fork lower, and the threaded end should be flush with the end of the nut on the left side. It looks like the axle was never tightened up, but left several mm loose for some reason.
Offline monkeyrocco
Re: F c m wheels
« Reply #7 on: September 01, 2016, 11:52:32 PM »
Thanks I will sort the axle  it will need fresh tyres anyway,  the bike was imported from Italy and left in a garage for many years the odometer  readings 19000 k . It found its way into a racer friend of mine s collection .I now believe that the rear calliper is a campagnolo, could the c in fcm be campagnolo ? If so they could be magnesium which will please Bomber man as they should burn well.
have fun ride safe
  • Holy Cow! I'm a
Re: F c m wheels
« Reply #8 on: September 02, 2016, 01:26:46 PM »
I always wanted to do a kings funeral with a well placed flaming arrow.
Offline Tim2005
Re: F c m wheels
« Reply #9 on: September 02, 2016, 03:39:06 PM »
I've never seen wheels like that. All the Campags I've seen are quite different, with just a single rib down the spokes.  Those Bimota 400f kits are really rather rare, they only made about 15, I was in touch with a guy in Ohio 10-15 years ago who told me about them. He was rebuilding one at the time but passed away, no idea what happened to it (yes, there is a company remaking them now in Italy too, mostly for the Japanese market). The original kit came with the tank, frt. fender, seat/tail section, and a very trick alloy swing arm, wheels were either EPM or a 5-point star/ pentagram type similar to a Shelby-Dowd wheel. Interesting caliper mounts on the fork-  are they 33mm forks still?
Offline monkeyrocco
Re: F c m wheels
« Reply #10 on: September 03, 2016, 04:53:46 AM »
Standard 33mm  just both fork legs from the disc side I presume, thanks for the info, I know the h1 had the trick swing arm , still think the bodywork is genuine been in my mates shed too long to be a copy.
have fun ride safe
Offline Tim2005
Re: F c m wheels
« Reply #11 on: September 03, 2016, 06:31:03 AM »
Doesn't look like another left leg reversed, and Honda RSC did used to sell a right leg kit with the caliper brackets, different internals and springs for both legs too, I found one here in the UK some years ago. Would be rather pricey now.
Here are some thumbnails of the Ohio bike, from 2002, the replica kits weren't available then, they are much more recent. This one had 7 point Shelby-Dowd style wheels, so the kits certainly varied a lot.  Is there a photo of the right side of yours? Curoius about the exhaust...
https://web.archive.org/web/20021114084602/http://drdetail.hypermart.net/html/1024/streetbikes/1975_honda_bimota_cb400f_racer.htm
Offline monkeyrocco
Re: F c m wheels
« Reply #12 on: September 03, 2016, 08:10:07 AM »
Thanks Tim seems your right just assumed the fork was nothing special, the exhaust system  is marving will take a pic of the right side asap it's throwing it down today. Cheers for the info
have fun ride safe
Re: F c m wheels
« Reply #13 on: September 03, 2016, 04:20:37 PM »
I seriously doubt it original, replica kits have been made for over 30 years, Tamburinni only sold 9 or 10 HBI kits and they were very expensive, if that was original it would be worth a fortune and would more than likely be on a 750, not a 350. Anyway, that tank wouldn't fit on a Bimota frame, and an original Bimota HB1 tank would not fit on a Honda frame,  if you'd seen the difference in the frames you'd know... ;)
Sorry to disappoint you...
« Last Edit: September 03, 2016, 04:28:30 PM by Retro Rocket »
Offline monkeyrocco
Re: F c m wheels
« Reply #14 on: September 03, 2016, 10:52:16 PM »
Hi not disappointed at all I didn'tmean a original 750 kit I know there was only ten I meant a original 400 replica tank seat and fender as opposed to a recent one. Still pretty rare I think? I am happy with it anyway. Thanks for the input.
have fun ride safe
Re: F c m wheels
« Reply #15 on: September 04, 2016, 12:06:13 AM »
No worries, as long as you are happy with it, thats all that counts... ;)
Offline Swoop
Re: F c m wheels
« Reply #16 on: September 04, 2016, 04:33:10 AM »
Offline monkeyrocco
Re: F c m wheels
« Reply #17 on: September 04, 2016, 02:15:26 PM »
Yes possible but unlikely, but two questions remain the wheels and if only 14 ever turn up is it as bad as my dad burying a rudge Ulster ? All I know is it came in from Italy more than 20 years ago and hasn't been touched , cheers guys for the info.
have fun ride safe
Offline monkeyrocco
Re: F c m wheels
« Reply #18 on: September 04, 2016, 02:25:14 PM »
Done it again missed out a full sentence , should read if bombers burns it and only 14 turn up ! Never mind had too much wine now, did have a good day at the national motorcycle museum though , zzz boring myself now night all have a great d tomorrow
have fun ride safe
