Author Topic: CB550 Crankcase Dowels/Orifice Selection  (Read 888 times)
Offline paulschell
« on: August 31, 2016, 11:58:41 AM »
Hey guys!
Easy question here, just wondering if these are the right dowels to use on the crankcase?
I order them from bike bandit and they said these are the ones, but I've seen different ones installed before, ones that actually look like an orifice, not just a dowel.
Thanks
Offline DaveBarbier
Re: CB550 Crankcase Dowels/Orifice Selection
« Reply #1 on: October 10, 2016, 01:53:15 PM »
Not sure if you sealed up the top end, but these dowels are wrong. They have to be 12238-323-000.
If it's all sealed up like this, open it back up!
Offline Bodi
« Reply #2 on: October 10, 2016, 06:29:41 PM »
Wow. Definite fail from bike bandit!
Those end holes, unless I'm super confused, carry oil to the valvegear. The lower one (case/barrels) should be the "oil control orifice valve", something like a pilot jet that restricts oil flow to allow enough oil past for valvegear lubrication and restricting it enough to keep main gallery pressure up. The upper one is a tubular plain dowel with an O-ring at the joint.
Using solid ejector pins as shown will have you stopped with a trashed head, cam, and maybe rockers and their shafts - within a few miles of home.
