Author Topic: Wiring Harness Differences  (Read 661 times)
Offline Imago
  • 1978 CB750F
« on: September 01, 2016, 05:42:30 AM »
I see in various on-line shops the wiring harnesses for K's are different for:
69 through 71
72
73 through 75
76.
Mines a 76. And more expensive.
Does anyone know the difference between a 75 and 76?
Can I use the 75 and save $25.00, (he said frugally).
Re: Wiring Harness Differences
« Reply #1 on: September 01, 2016, 01:25:08 PM »
Go to OldManHonda and compare schematics - there is just more sihte with later years - could be running lights for instance.
Any harness will work, just some will need to be adapted more than others
I used 78f harness on my build - but went with old NOS turn signals. I removed running lights wires from the harness, did not need them. Also the whole nonsense of safety module.
« Reply #2 on: September 01, 2016, 01:26:39 PM »
I also added a wire - from battery to headlights relays.
Online CycleRanger
  • No comment about being an
« Reply #3 on: September 01, 2016, 02:11:46 PM »
69 through 71
72
73 through 75
76.
The '75's still had an on-off switch for the headlight. The '76 headlight was always on.
I think the starter safety switch is different as well.
You can compare the 75-76 diagrams in the shop manual supplement.
