Author Topic: 550 backfire  (Read 1161 times)
Offline 550Resto
550 backfire
« on: September 04, 2016, 11:49:11 AM »
Hello all, I have a 78 550 that on hard deceleration backfires. I've changed the mains to 100 from 90, I have a delkevic 4into1 with stock airbox. Carbs were rebuilt by harisuluv. I'm wondering if I should go up one more size on the mains or not? I can hammer down and get through the gears with no hiccups or backfire on hard acceleration. Any help is appreciated.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: 550 backfire
« Reply #1 on: September 04, 2016, 12:24:43 PM »
The simplest thing to check first are your airbox and carb connections.
Decel pops were first explained to me as result of too much air.  Even if not a Lean condition.
550's were built to run on 90 mains.  Try a different needle clip position maybe?
If you had an old forties harley, that pop would almost be considered normal  ;D
Offline b52bombardier1
Re: 550 backfire
« Reply #2 on: September 04, 2016, 05:01:43 PM »
Do you have a hole in your exhaust pipe or a loose pipe at the manifold end?   That would allow air in to complete combustion that will make the backfire sounds.
Rick
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
Offline DaveBarbier
550 backfire
« Reply #3 on: September 05, 2016, 04:46:19 AM »
Just because it's so easy to test on PD46C carbs, I'd clear tube them. Were they rebuilt recently? Fuel system above the carbs clean?
Ever done plug chops to see where your mixture is at various throttle openings?
Might also want to check for air leaks before the carbs, at the carbs and after the carbs including between the manifolds and the head with some flammable liquid spray (carb cleaner works but eats paint so I tend to avoid that) or propane.
Offline Lostboy Steve
550 backfire
« Reply #4 on: September 05, 2016, 05:14:35 AM »
How loud of a pop are we talking? My 77 has always had a bit of a gurgle on decel. Not superloud, but it's there. I should add that my plug chops are just about perfect.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
