Author Topic: CNCing aluminum  (Read 1444 times)
Offline trenchgrinder750
  • 78 CB750F
CNCing aluminum
« on: September 06, 2016, 06:29:57 AM »
I have a nest base cnc and cut mostly plywood, solid wood and acrylic.  From time to time I'm machining aluminum I'm always looking to improve time and quality.  I've found 6061 alloy cuts the best for me from 1/8" to 2".  using onsrud 63-600series 1/8",1/4",3/8" and 1/2"single flute upcut bits and a chipload of .008" with 3/16" passes.
Am I on the right path? I feel like image 2 can have a better edge.
78 CB750F
Offline Steve F
Re: CNCing aluminum
« Reply #1 on: September 06, 2016, 06:34:27 AM »
Personally, I think .008 is a bit much to expect a good finish.
Try around half that to make finish passes, and keep your tooling chucked up as short as possible.  It looks like the tool is bouncing giving you the fluted look on the sides.  Rigidity is your friend.
  • 78 CB750F
Re: CNCing aluminum
« Reply #2 on: September 06, 2016, 07:20:45 AM »
definetly to much vibration.  that was with a 1/2" tool.  I'm going to try a 3/8" with a 5/8" cut length in a shrink fit tool holder and around half the chipload for final pass.  hopefully today, if not, later in the week.
and thank you
78 CB750F
Offline Thekramer666
Re: CNCing aluminum
« Reply #3 on: September 06, 2016, 08:48:07 AM »
Your on the right track now :) yes small passes for finish and u can usually fly thru them if u wanted too depending on your cutter of course carbide is my go to but $$$ work pays it so not an issue here goodluck
Please check your messages & follow up on your posts!!
76' CB550F SS
Re: CNCing aluminum
« Reply #4 on: September 06, 2016, 08:54:35 AM »
Use a 2 flute or 4 flute, double or quad  the feedrate.
 Unless your machine weighs at least a ton,  you will probably have rigidity issues, often that can be solved with a light finish cut, climb milling.
Offline J-Rod10
Re: CNCing aluminum
« Reply #5 on: September 06, 2016, 12:22:24 PM »
I like the OSG 3 flute blizzard cut on alloy. I run it fast and hard.
  • 78 CB750F
Re: CNCing aluminum
« Reply #6 on: September 09, 2016, 06:09:30 AM »
definetly weighs more then a ton, and sits on 8" slab of cement.
I'm going to try those OSG bits.
YEP! bosses CC
I haven't had a chance to try any of this out yet, work will slow down in a week or so.
78 CB750F
Re: CNCing aluminum
« Reply #7 on: September 09, 2016, 05:17:05 PM »
What is a nest base ? Are you talking mill or a router... Show a pic of the head, or give us a model number. I suspect it s maybe a gantry style router....what is the Z travel...approximately..?
« Last Edit: September 09, 2016, 05:26:34 PM by 754 »
