Author Topic: PD41A vs PD41B carbs .. 77 CB750F  (Read 3290 times)
Offline hashvm
  • It's not a lesson without you making mistakes!
« on: September 07, 2016, 10:38:49 PM »
Here we are again .. I hope you all are enjoying your summer rides
A while back I started a thread about the 1977 CB750F I bought over summer (I also have to update the thread  ;D )
I managed to get the bike running (First time in about 10-ish years?)
and last week I managed to get it moving and stopping on its own! (It was last registered in 96 so you do the math  ;) )
However, when I finally got it running, two of the four cylinders were firing (2&4)
They all have new plugs .. new timing plate and statically timed ..
Things I haven't done yet: valve adjustments and Timing chain adjustments ..
So today I took the carbs off again .. and opened them up
As you can see on of the carbs (#4) has one of the float rod's posts broken .. any way to fix that?
While I had the carbs open I noticed something about the non-running cylinders (I suspected carbs to be the cause of the problem)
Carb #1 had the floats pin sticking outwards that it hits the bowl when they come on, causing the floats to stick in the up position (closing the valve needle circuit and not causing fuel to flow to the carb body?)
and carb #3 had the needle valve's spring loaded stuck (I took it out and manged to get it working)
So tomorrow I'm gonna put them back on and hope that all four would fire!
Another question: anybody knows why carb #4 keeps getting this white powder?
Here is as she sets now
Along its other sister (my 1980 CB750F)
I hope to get this running in time soon so I can enjoy it a little bit before the cold, and my engineering classes get serious!
Hashem
« Last Edit: September 22, 2016, 08:13:14 AM by hashvm »
Offline hashvm
Re: Another carb question .. 77 CB750F
« Reply #1 on: September 08, 2016, 08:10:27 AM »
Just put the carbs back on with no luck  :(
Cylinders 1,4 still don't fire
Is there anything I'm missing here?
Online madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: September 08, 2016, 08:20:54 AM »
First you say "two of the four cylinders were firing (2&4)"
then you say "Cylinders 1,4 still don't fire"
So which is it? What are you using to determine whether these cylinders are "firing" or not? Are you getting spark to these cylinders? If you're not getting spark (not firing) then why are you taking the carbs apart?
"Firing" to me means "spark".
Finish the rest of the 3K tune up (valve adj, timing chain tension, etc.), then determine whether spark is present for all cylinders, and report back.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #3 on: September 08, 2016, 08:39:25 AM »
No way a float will operate properly with a broken post.
That carb will always cause running issues.
If the post piece was in the bowl, it can be micro welded back on.  A forum member here offers that service.
or....
Contact forum member harisuluv....he buys/sells carbs/parts....and probably has a dozen of these carb bodies ready for use.
« Reply #4 on: September 08, 2016, 09:17:32 AM »
 The white carb looks to have had a bunch of water in it at one time probably and like a cancer the corrosion keeps returning. Don't waste your time putting them back on till the post is fixed proper or the carb body is replaced with a better one(my choice).
Offline hashvm
« Reply #5 on: September 08, 2016, 10:06:22 AM »
My bad .. I meant Cyl 1,3
what i mean by saying they aren't firing is the two exhuast stay cold and don't heat up as the other two
all have new spark plugs and they all have sparks (i checked them)
I'll try to finish the 3000mi tuning soon
thanks
Offline hashvm
« Reply #6 on: September 08, 2016, 10:08:47 AM »
or....
When I first opened the carbs this particular one had some sort of material that looked like clay to hold the pin
the weird thing is this carb is attached to one of the firing cylinders
I'll pm harisuluv .. Thanks!
Offline hashvm
« Reply #7 on: September 08, 2016, 10:10:22 AM »
Thanks .. I'll try to find a replacement as I was planning on getting her running soon  :-\
Offline hashvm
« Reply #8 on: September 22, 2016, 08:12:43 AM »
So unfortunatly I couldn't find a parts PD41B carb (that's the one for the "77 CB750F) .. however, I was able to get a body of a PD41A (from a "77 K model) .. anybody knows if these two are different?
I looked around and I can't see to find any differences except for jets and needle positions which are I can easily change
Offline Ericcb750
Re: PD41A vs PD41B carbs .. 77 CB750F
« Reply #9 on: September 22, 2016, 08:20:10 AM »
You're absolutely right on that, The PD41A and PD41B are literally identical except the jetting (Main jet size). The A's were for the F model and the B's were for the K's . I know on my PD42B's the jets were 35pilot and 110 main with non-adjustable needles. The PD42A had 35's , 115's and non-adj needles.
I think the PD41's are pretty much the same except they have the adjustable needles and I think the Slides were not hard chromed or something..... Someone else may be able to chime in and clarify.... The float setting may be a couple mm's different too, but as far as swapping parts , I think you're good to go with that , No problems that I can see.
1978 CB750K
1978 CB750F super sport
2005 Sportster 1208
Offline hashvm
« Reply #10 on: September 30, 2016, 07:41:45 PM »
Thanks Eric, It's been a while and I've been working on wiring my other 76 CB550 project from the ground up .. I'll differently let you know if this works!
« Reply #11 on: September 30, 2016, 09:42:38 PM »
 I fixed a post by JB welding a brass bullet cartridge over it after drilling the post hole first. I made it slide on until the pin was in the notch left on the post. It was a wildcat round something about a bee. Sorry, I found it in my brothers tool box.
