Author Topic: 76K Honda Head with new sleeves  (Read 826 times)
Offline Dizzle
« on: September 08, 2016, 04:25:43 PM »
I had new sleeves put on my old head by a machine shop. I'm putting it back together now and noticed that the sleeves don't sit totally flush with the head. One sleeve is 1.5mm raised from the head. My question is are all the sleeves supposed to be perfectly flush? Is 1.5mm raised from the top of the head ok?
Thanks for the help!
Offline eigenvector
Re: 76K Honda Head with new sleeves
« Reply #1 on: September 08, 2016, 04:27:26 PM »
That's pretty proud of the head.
At the very least the gasket wouldn't seal well
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: September 08, 2016, 04:37:42 PM »
Where to sleeves go "in the head"? Do you mean new cylinder sleeves installed in the cylinder block? If so, then yes, the cylinder sleeves should fit flush with the top of the cylinder block. The sleeve might have gotten pushed out in transit. They can be displaced, especially if a freshly painted set of cylinders is placed in an oven to cure. I've heard stories where the cylinder block slid off of all four sleeves at once, although I've never seen it. If you've got a press, you can try to press the cylinder back into place, or you can take it back to your machinist and he would likely be happy to press it back in place. The cylinders should sit perfectly flush, and the top of the cylinder block (with sleeves installed) are often milled to provide a perfectly flat surface. I would not use the head to press the cylinder back into place.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
