Greetings!
I've owned a 1974 CB550 for a few years now and I'm working through the process of getting it running. I had the carbs rebuilt, and purchased a replacement tank as the other one was hideously scaled with rust.
This new tank has a hole on which the petcock is screwed on, rather than bolted on with 2 screws. I have read on this thread that it came from one model of one year, the 76' supersport. The guys at Honda ditched the design because it was evidently irreparable and prone to damage from any rust or particles in the tank.
It can be found on eBay:
http://m.ebay.com/itm/Honda-CB-550K-550F-550-F-K-CB550-NOS-petcock-1975-76-/232068102484?_trkparms=aid%253D222007%2526algo%253DSIC.MBE%2526ao%253D1%2526asc%253D20150519202348%2526meid%253D6b938ff85d9c4db2b75944ce34589a4e%2526pid%253D100408%2526rk%253D1%2526rkt%253D1%2526sd%253D231995364905&_trksid=p2056116.c100408.m2460)
..... buuuuut, I don't want to buy it. First, it seems to be horribly designed and will not last long. Secondly, it's $96 + shipping (for a petcock!), And thirdly, I cannot be sure I can find a new one again as they seem very rare. I bought the tank not knowing I would be faced
I had heard though, on other threads that a CB750 petcock can be had and fit the tank exactly like the original with the easy addition of a T splitter in the fuel line. It can be found here:
http://m.ebay.com/itm/Honda-CB750K-CB750F-CB-750K-750F-Petcock-19mm-CB750K-75-76-CB750F-75-76-CB550-77-/221171456740My question is for you experienced and versed men of Honda motorcycles, can they actually be used interchangeably. I thought they could at first, but the ad for the cb750 petcock says it has a 19mm thread, and the one meant for the tank says 20mm according to the seller if you look at the links.
I am on no schedule, but I'd like some direction on this issue. I can help with any extra information you may need.
Thank you for your advice,
Lawrence
