Author Topic: 1978 CB550K - new project - COMPLETED  (Read 26584 times)
Offline my name is nobody
  • I like Pontiacs and Hondas
Re: 1978 CB550K - new project
« Reply #100 on: June 20, 2017, 03:56:39 AM »
The one you are pointing at on the plenum chamber is a drain hose port. Parts diagram will help you see it. Next is The breather hose goes from valve cover port
down and between carbs 3/4 and thru the triangle on the battery side, connecting with fitting on side of air box. Last hose goes from bottom of air cleaner housing straight
down, a drain for the water separator
Offline Johnie
« Reply #101 on: June 20, 2017, 05:37:09 AM »
Gosh thanks a lot man. That really helps me out. Getting real close now to finishing this one up.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #102 on: June 20, 2017, 07:50:43 AM »
Nobody knows what he is talking about.  When nobody will answer you feel like no one is reading your thread...yes, I stumble trying to be funny...
I must be ready to write a performance appraisal as that first sentence could be read two ways with polar opposite meanings. ;)
I am glad Nobody has you squared away. ( It couldn't happen to a nicer guy...   )You did pay a princely sum for this bike, it makes my heart skip a beat thinking you are just going to sell it.
Offline Johnie
« Reply #103 on: June 20, 2017, 10:26:45 AM »
Selling it RAF has to do with the amount of space I have here. Who knows, maybe no one will buy it and I will find space. I just have a real soft spot for the 750's. Those are a lot harder to part with.
Oshkosh, WI  USA
Offline Johnie
« Reply #104 on: June 20, 2017, 03:05:37 PM »
Still questionable on that vent hose. I hook the hose up to the air box nipple near the battery and end up with 10 inches extra routing it between carbs 3 & 4 to the valve cover nipple? First pic my screwdriver is pointing to the area near the battery box where the hose is connected. 2nd pic shows the 10 inches extra hose I have? After digging through the Honda service manual I came across pic #3. Sure enough, that vent hose does go to the bottom of the air box like "nobody" says. It is part of the "new feature of the CB550" to minimize pollution per the manual. I have a feeling the PO decided to bypass it for some reason and got a longer hose to vent behind the center stand. I can cut it off and put it where it belongs, but does it really make a difference? I mean all the 750's vent to open air.
« Last Edit: June 20, 2017, 03:45:41 PM by Johnie »
Oshkosh, WI  USA
« Reply #105 on: June 20, 2017, 05:42:48 PM »
John, the way you have it hooked up, it looks right. At least for a 550 k0.
Can't say exactly why there is so much leftover hose tho, unless the later 550
like yours has a different pcv system. Maybe someone with more knowledge
can enlighten us...
EDIT pcv hose goes DOWN btween INTAKES 3/4 and then UNDER carbs on the way to triangle...sorry for mis information. Hope it didn't cost you a lot of time...
« Last Edit: June 20, 2017, 06:11:11 PM by my name is nobody »
Offline Gene
  • Chat enuf you too can be a
« Reply #106 on: June 20, 2017, 05:50:06 PM »
In reply 102 - that's exactly where it's supposed to go from the breather.
That said, I don't have mine hooked up on my 550, though it's a different year.
*1973 CB750K3 (Bow)
« Reply #107 on: June 20, 2017, 08:13:18 PM »
Yes, it does go where you have it...the filter stack with several of those no longer available rare parts  collect the oil vapor and the moisture and  oil that collect drip into the bottom of the airbox into the drain.  The drain hose has that no longer available pinch to open valve and their is a foam filter element inside that end of the valve. It takes any unburnt gases in that vapor and brings them back through the carbs to burn those vapors. Really no downside of using the design as opposed to venting to atmosphere.  You typically don't see oil stains on the filter when the filter stack is working with the foam and other pieces in that stack.  So, having the motor rebreath those fumes is more environmentally friendly.  The oil vapor is tough to contain otherwise and with the moisture it usually looks foggy on cold mornings and you don't have a mess on the motor from that vent if not rerouted.
It is too bad some of the cool hydraulic storage rack systems for multiple bikes are not much cheaper, they could make having more bikes in a more compact area, if you have the headroom to support their use.
Offline Gene
« Reply #108 on: June 21, 2017, 05:38:04 PM »
Sent a PM - but, just in case, found this addendum for years 76 - beyond re: the breather tube.
http://manuals.sohc4.net/cb500/service_manual/HSM500550_15.pdf
If I'm confusing the issue let me know and I'll back out.
*1973 CB750K3 (Bow)
« Reply #109 on: June 21, 2017, 08:38:44 PM »
That diagram showing the small sleeve tied to the frame at the top also looks
correct. Mine is as described/ edited in my earlier post, but is for a k0 model,
like the pic john posted earlier.
so there probably are differences between models. I'm getting confused too, so I'm gonna cool it and see what others say.
« Last Edit: June 21, 2017, 08:59:49 PM by my name is nobody »
Offline Johnie
« Reply #110 on: June 22, 2017, 07:32:49 AM »
Don't back out guys. Your info is very helpful. Just for reference:
Engine #2100717
Frame #2100707
Build date 6-77.
The Honda spec sheet Gene attached shows the breather vented to open air. I will post a general question on the board for a 78 CB550K and see what I get...
« Last Edit: June 22, 2017, 08:24:22 AM by Johnie »
Oshkosh, WI  USA
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=lvptjts5usl94ah6jj8cgbbn90&/topic,60973.0.html
« Reply #111 on: June 22, 2017, 12:54:39 PM »
this is taken from my honda service and parts promotion book..for my cb 550 k3-1978.
.but i dont use it ..my airfil´ter vas been dirty bu oil damp..and after rebuild i dont have any damp or pressure aut of it..so have put a small paper filter direkt at the cover..to neutral the pressure inside the engine..at the Photo you can see the Black 12 mm thik tube,,go dovn  i think between karb  3 and 4..and normaly konnekt to pos 23(i think)
« Last Edit: June 22, 2017, 01:07:57 PM by strynboen »
i hate all this v-w.... vords
« Reply #112 on: June 30, 2017, 04:04:34 AM »
Ever get a definitive answer or solution John? Or just make a decision based on
information already mentioned? Just curious...I'm lookin forward to seeing how this one turns out.
« Reply #113 on: June 30, 2017, 07:56:00 AM »
or....can we get an update on the kitchen?!
« Reply #114 on: June 30, 2017, 10:01:17 AM »
Probably will need to get Mrs. Johnie's read on it being done if she is like most wives, it is a good thing they do not work in software development.  In that world having a fixed end date with 2% feature expansion/feature creep causes project failure nearly everytime.  So, the requirements for the product being built have to be controlled, frozen and any modifications to plans must be negotiated and schedules and even cost impacts taken into account...
So, it is a good thing Johnie is not the primary contractor doing that project.
If they were smart they would write in a completion clause with financial rewards or penalties and tightly controlled exceptions for any schedule slips not agreed to by both parties...
That can be hard to get a contractor to agree to because of the rampant schedule abuses in the building and remodeling industry.
Offline Johnie
« Reply #115 on: June 30, 2017, 11:33:18 AM »
Ok...kitchen almost done. Waiting on the tile then the electrician can finish. The 550...I found the plenum hose from a dealer in OH and got that this week. Also picked up some OEM hose clamps from my dealer. I can get those on this weekend...hopefully. Will have to repair the hose on the bottom of the air cleaner drain as that is not available anywhere. It is a 2 diameter hose broke off at the narrow. Then will do some cleaning on the inside of the tank and it should be a go. We are expecting a grand daughter to be born around the 4th. A lot of irons in the fire this summer. Plus, this is the time to ride not hide in the shop.
Oshkosh, WI  USA
Offline Johnie
« Reply #116 on: July 16, 2017, 12:56:19 PM »
Progress...July 3rd became a grandpa again. This time a little girl Everly Grace. So with the kitchen about done and the baby here...today I connected 2 cooling fans, my auxiliary tank and she fired right up. Did the Morgan carb sync and she idles great. Just need to put on the tank, side covers, seat and take it for a test ride and will call this one done.
« Last Edit: July 16, 2017, 01:08:21 PM by Johnie »
Oshkosh, WI  USA
« Reply #117 on: July 16, 2017, 02:44:46 PM »
Honda Service at it's finest, bikes, babes and kitchens!!  Congrats on the little one.
« Reply #118 on: July 16, 2017, 03:20:59 PM »
Congratulations on the new addition!
I like the Honda Service sign, too!
« Reply #119 on: July 17, 2017, 02:19:43 AM »
Congrats Johnie on being a grandpa!  Give her time, she will have you wrapped around her finger... ;D
David
Offline Johnie
« Reply #120 on: August 11, 2017, 12:55:13 PM »
Last item - took the old gas out of the tank and it's really clean, but with a few stains on the bottom only I decided to use some Metal Rescue on it. I hate to mess up the nice carb rebuild that harisuluv did for me by having any junk get into them. The OEM petcock works excellent and the OEM in tank fuel filter is in great condition. Check out the original paint. Side covers just as nice.
« Last Edit: August 11, 2017, 12:56:52 PM by Johnie »
Oshkosh, WI  USA
« Reply #121 on: August 11, 2017, 02:06:55 PM »
oooh...shiny!  Almost time to ride that sukka!
« Reply #122 on: August 11, 2017, 03:42:03 PM »
Wow. Pretty tank!
Offline Gene
« Reply #123 on: August 11, 2017, 04:52:52 PM »
Wow. That's gorgeous. I know I have a penchant for Orange bikes, but I've always loved the Honda Brown.
*1973 CB750K3 (Bow)
« Reply #124 on: August 11, 2017, 04:58:55 PM »
Brown? Johnies tank is Excel Black.  Candy Garnet Brown was '77...
