Author Topic: Carburetor Rubber Overflow Tubes - Where to Buy ?  (Read 1567 times)
Offline whitjonw
  • Motorcycle Maniac
« on: September 13, 2016, 05:32:59 AM »
I am looking for the rubber overflow tubes and haven't seen any available from any of the suppliers I have looked at. Where are you guys purchasing these from and if none are available is there a good substitute from the local auto parts suppliers ?
1973 Honda CB500 K2
1974 Honda CL200 Scrambler
1974 Honda CB750 K4
1976 Honda CB750 K6
This is our life, this is our song.....
Re: Carburetor Rubber Overflow Tubes - Where to Buy ?
« Reply #1 on: September 13, 2016, 05:56:12 AM »
 If not doing a correct resto Tygon lines come in many sizes small to large. See it at Napa and many other places. If you really want to go cheap clear aquarium line would probably work also since its not immersed in gas.
« Last Edit: September 13, 2016, 05:58:18 AM by ekpent »
« Reply #2 on: September 13, 2016, 06:36:43 AM »
Windshield washer vacuum hose.  10' should run you just a few $ and is enough to do all and trim to fit under your swingarm.
Your carbs are perfect and they'll never overflow, so not being fuel resistant is not an issue  ;)
Offline whitjonw
  • Motorcycle Maniac
« Reply #3 on: September 13, 2016, 07:52:59 AM »
Right !
Thanks guys, I will check those items out.
1973 Honda CB500 K2
1974 Honda CB750 K4
1976 Honda CB750 K6
Offline firebane
« Reply #4 on: September 13, 2016, 09:45:25 AM »
5.5mm fuel hose from 4into1 if you want factory style.
« Reply #5 on: September 13, 2016, 09:56:33 AM »
5.5mm 3.5mm fuel hose from 4into1 if you want factory style.
FTFY  ;)
Offline edwardmorris
  • Youngish
« Reply #6 on: September 13, 2016, 10:21:56 AM »
Pretty cheap and available from Honda, use these part numbers for ref.
Fuel hose
Part number    - ID    - Appearance
95001-3500160M - 3.5mm - Black
95001-3500150M - 3.5mm - Black, braided exterior
95001-4500160M - 4.5mm - Black
95001-4500150M - 4.5mm - Black, braided exterior
95001-5500160M - 5.5mm - Black
95001-5500150M - 5.5mm - Black, braided exterior
95001-7500160M - 7.5mm - Black
95001-7500150M - 7.5mm - Black, braided exterior
Vacuum hose - 1 Metre long
95005-3500120M - 3.5mm - Grey
95005-4500120M - 4.5mm - Grey
95005-5000130M - 5.0mm - Black
95005-5500120M - 5.5mm - Grey
95005-7000150M - 7.0mm - Black
95005-7500120M - 7.5mm - Grey
95005-8000120M - 8.0mm - Grey
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #7 on: September 13, 2016, 03:45:17 PM »
I picked up fuel resistant transparent red tubing from ACE.
It's the place with the helpful...you know.
Offline Gene
  • Chat enuf you too can be a
« Reply #8 on: September 13, 2016, 03:46:44 PM »
This is what I use.
*1973 CB750K3 (Bow)
Offline whitjonw
  • Motorcycle Maniac
« Reply #9 on: September 13, 2016, 04:57:49 PM »
I think I like the 3.5mm fuel line from 4 into 1 option the best. Awesome, thanks !
1973 Honda CB500 K2
1974 Honda CB750 K4
1976 Honda CB750 K6
« Reply #10 on: September 14, 2016, 01:00:37 PM »
Just get a black hose the proper ID and don't worry about fuel resistance.
