Author Topic: Chain Oiler Delete  (Read 5795 times)
Offline MattFreeman
  • What Have I Done?
Chain Oiler Delete
« on: September 13, 2016, 05:57:10 AM »
Looking for some advice on what I think is a oiler related issue. I'm finishing up my '76 750F1 project and since I've gotten alot of advice here and have never gotten it together to start a build thread here's a pick form last years "work out the bugs before final assembly". I've since finished the frame and I'm reassembling for the final time (hopefully). So I'm workin out the last of the bugs.
The issue: Getting tons of oil in the front sprocket area and on the chain. Long ago I had read something about plugging the oiler so I found a hole in the final drive shaft that I believed to be the oiler and welded it closed. Obviously this didn't do what I thought it would do as I'm bathing in oil from the chain when I ride this thing.
The interesting thing to me is that there is a large threaded opening at the end of the drive shaft where you would think a bolt would go to hold the sprocket on. I've looked at parts fiches and they only show a plate the turns into a notch on the shaft and two bolts holding it and the sprocket to the shaft. Is stopping the oil as simple as finding and installing a bolt here?
Thanks in advance.
Side note: The search function is not working on my browser at all.....
« Last Edit: September 28, 2016, 05:09:02 AM by MattFreeman »
Re: Chain Oiler
« Reply #1 on: September 13, 2016, 06:29:54 AM »
 What serial number is your engine, 1976 F1 model engine did not have an oiler.
Offline MattFreeman
  • What Have I Done?
Re: Chain Oiler
« Reply #2 on: September 13, 2016, 06:38:27 AM »
Its an F1.
I would certainly believe that the oil is coming from something else. The seal is new and the cases bonded well. Something else?
Re: Chain Oiler
« Reply #3 on: September 13, 2016, 06:56:44 AM »
1975 was the last year for the oiler, any cracks in your case around the sprocket ? Is your engine serial number above 250xxxxx4 ? You said you replaced the shaft seal correct.  A picture of the sprocket shaft may be good for the F gurus like Jerry RX.
« Last Edit: September 13, 2016, 07:00:57 AM by ekpent »
Offline MattFreeman
  • What Have I Done?
Re: Chain Oiler
« Reply #4 on: September 13, 2016, 07:49:09 AM »
My serial # is e-252xxx4. And the main seal is new. Photo forthcoming.
Offline MattFreeman
  • What Have I Done?
Re: Chain Oiler
« Reply #5 on: September 13, 2016, 11:27:16 AM »
Here's what we've got for a photo.
Offline przjohn
Re: Chain Oiler
« Reply #6 on: September 13, 2016, 01:50:13 PM »
I just finished a 76F and there is no chain oiler that I saw. Are you oiling the chain a lot with regular oil and not chain oil and that is what you are seeing or do you have an oil leak near the countershaft?
Offline qside
Re: Chain Oiler
« Reply #7 on: September 13, 2016, 02:18:47 PM »
This is probably not what you are seeing but I have had leaking from my left side engine cover from the screw holes. previous owner replaced screw with allen bolt and the bolt head wasnt wide enough to seal the plug hole. Dripped forever until I replaced the bolt with stock screws.
Offline MattFreeman
  • What Have I Done?
Re: Chain Oiler
« Reply #8 on: September 13, 2016, 04:42:01 PM »
Never put any lube on it, was always oiled. Assumed it was an "oiler" issue. Guess the thing to do is fill it with oil, take the sprocket off and starter up.
Re: Chain Oiler
« Reply #9 on: September 13, 2016, 07:18:16 PM »
Matt, you have the early type counter-shaft. The oil enters the center of the inside end of the shaft, and exits through the hole in the side. Since you have welded the side hole, all you need to do is thread an M14x 1.25 bolt or set-screw (with an appropriate sealer) into the shaft to plug the outside end.
Re: Chain Oiler
« Reply #10 on: September 13, 2016, 07:30:40 PM »
I will be making some oiler eliminaters bolts soon.
Re: Chain Oiler
« Reply #11 on: September 13, 2016, 08:15:58 PM »
Frank, FYI the stocker weighs about 26 grams. ;)
Re: Chain Oiler
« Reply #12 on: September 13, 2016, 08:22:34 PM »
Thats FATASS..mine is 10.1 grams plus the o ring..
« Last Edit: September 13, 2016, 08:24:25 PM by 754 »
Re: Chain Oiler
« Reply #13 on: September 13, 2016, 08:46:55 PM »
 ;D ;D
Offline Davez134
Re: Chain Oiler
« Reply #14 on: September 13, 2016, 09:24:17 PM »
I was waiting on that photo, and just saw it now. Scottly is right on, that shaft is from an earlier bike. Just plug the end with the bolt size he mentioned. (Or get one from Frank, I'd like one too!)
Offline MattFreeman
  • What Have I Done?
Re: Chain Oiler
« Reply #15 on: September 14, 2016, 08:17:50 AM »
Awesome!! I bought what was sold as a F1 trans awhile ago with extra stuff so I'm not surprised that it's not a F1 shaft. (it had a better bearing on it so I used it). I've been learning alot on this build and in some respects it's been a steep curve.
Thanks once again for all the help. Having that thread size is super helpful as well.
Offline Blue2swing
Re: Chain Oiler
« Reply #16 on: September 14, 2016, 08:31:48 AM »
More info and price please....
I spent $20 on a Joker Machines one, but I'd has to be pressed on, not threaded. It's currently resting semi-pressed in the shaft.
Re: Chain Oiler
« Reply #17 on: September 14, 2016, 08:38:13 AM »
Matt, check your chain aignment, just in case you have a wrong combo.
If you ran it a while look for sprocket rub on only one side..
Offline MattFreeman
  • What Have I Done?
Re: Chain Oiler
« Reply #18 on: September 14, 2016, 02:35:24 PM »
Copy that, Thanks!
Re: Chain Oiler
« Reply #19 on: September 14, 2016, 07:23:15 PM »
Frank, I got you beat by 4.8 grams. ;D Broached an internal hex with a sharpened Allen key; first time I've tried it..
Online PeWe
Re: Chain Oiler
« Reply #20 on: September 15, 2016, 03:03:06 AM »
This is something my CB750 need. I have just found out that I miss a fresh lock washer for the OEM oiler stuff, 90433-300-010
Your bolt need that washer too?
- Price? If washer is needed to lock it, you have that too?
Offline Hotwheelbill
Re: Chain Oiler
« Reply #21 on: September 15, 2016, 03:49:35 AM »
754, I would like two please.
I love to make my bikes worthless due to high mileage!
2004 ST1300A .... the fast one. And dragging pegs on a CT.
1972…parts bike
1974…. Rusty frame but runs
1974 CB750..... Powder coated frame and parts, waiting for $$ hot rod motor.
1972 with 1975 old school drag motor
Offline qside
Re: Chain Oiler
« Reply #22 on: September 15, 2016, 03:58:12 AM »
I could use one too
Re: Chain Oiler
« Reply #23 on: September 15, 2016, 04:12:43 AM »
 Better get busy Frankie  ;D
Re: Chain Oiler
« Reply #24 on: September 18, 2016, 11:17:16 AM »
I will start on them this week. If anyone want to pay  ahead, they get the first ones.
As I recall, 25 Us for one includes shipping, 47.00 for two shipped.
The head will be 18 mm , if i make them 19 they have to go parcel fir a much higher rate.
Paypal address is below thanks
