Author Topic: Oil Level  (Read 796 times)
Offline 550Resto
Oil Level
« on: September 13, 2016, 03:53:36 PM »
Question regarding the oil level... the manual states to unscrew the dip stick and then wipe it off and re insert without screwing it in. This seems odd to me as I'm not sure you'd get an accurate reading if not fully seated. Am I correct or no? Also is there oil that gets trapped in any other areas that wouldn't account for the level?
Bike is a 78 550K. Any help is appreciated.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: Oil Level
« Reply #1 on: September 13, 2016, 04:23:56 PM »
The area between the two marks is the "serviceable range"
Not threading it all the way in moves the serviceable range higher, almost 1/2"  reckon.
All it means is ya get to put a little extra oil in the engine
Offline DaveBarbier
Re: Oil Level
« Reply #2 on: September 13, 2016, 05:07:36 PM »
You'll get a fine reading. Some oil will stay up in the head and in the oil filter and cover. Honda must have accounted for that.
Center stand, dip stick unscrewed and the level should be between the lines. Nothin' to it :)
Offline jonda500
Re: Oil Level
« Reply #3 on: September 13, 2016, 05:14:01 PM »
With stationary motors they are are generally screwed in to check, with motorcycles they're dipped in without screwing in - that's just how it is...
John
A starter clutch thread:
Offline eigenvector
Re: Oil Level
« Reply #4 on: September 13, 2016, 05:14:36 PM »
I usually just give it a 1/4 turn to lock the threads so that it's secure (won't fall off into the grass).
But yeah - every small engine I own uses that method.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
