Author Topic: change of sprocket oil seal  (Read 941 times)
Offline _mark
« on: September 15, 2016, 07:13:19 AM »
Hi guys.
I need to change the Oil seal of the sprocket because is loosing oil.
First question. How can I force and put the seal inside the housing? there is not the space to pick it inside with an hammer and a nylon cylinder pad... the space is too confined to use the cylinder pad and if I remove the cover of the gearbox (red arrow), oil escapes out...
2 - oil seal could be also a not OEM one ?
Thanks
Re: change of sprocket oil seal
« Reply #1 on: September 15, 2016, 07:58:32 AM »
Take off the shifter lever and shifter cover.
Replace the seal.
Refill the lost oil later.
Offline _mark
« Reply #2 on: September 15, 2016, 10:56:10 AM »
Replace the seal.
Done. Thanks.
