SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Stripped Carb Bowl Screw- Question# 881
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Stripped Carb Bowl Screw- Question# 881 (Read 989 times)
briancwynn
If created then it is for a purpose!
Enthusiast
on:
September 15, 2016, 02:33:43 pm »
Okay all the screw thread for one of my carb bowls is stripped. This would be part of the body of the carb that is stripped and not the screw itself. My question is do I try and tap it for the same size or go up one size? Or should I do something else that you dont know until you ask? Thanks all for the help.
Logged
Honda CB750 1978 K
Stock Carbs w/ Pods
125 main jets, stock slow, and 2 shims on the needle (equal to about raising it one clip)
M-unit
Bike broken down to bare bones and slowly put back together (except for the engine)
flybox1
My wife thinks I'm a
Really Old Timer ...
Re: Stripped Carb Bowl Screw- Question# 881
Reply #1 on:
September 15, 2016, 02:37:06 pm »
No sense pitching the bowl. Try acorn nuts, and just get 4-5mm longer screws.
Tapping for next size up has been done.
Logged
'78 750K (F3 engine) PD42b's, Modified airbox w/K&N filter, 40/110 jets, 1 needle shim, IMS@ 1 turn out. Kerker + Cone 18" QuietCore
"This is my CB. There are many like it, but this one is mineā¦"
ekpent
To many bikes-but lookin' for more
Reply #2 on:
September 15, 2016, 03:54:16 pm »
You may be able to get by tapping up to the next size non metric screw bolt but just a guess without seeing it.
Last Edit: September 15, 2016, 07:36:41 pm by ekpent
Logged
jonda500
I may be crazy but I'm not stupid!
Master
With our thoughts we make the world (Monkey Magic)
Reply #3 on:
September 15, 2016, 05:12:12 pm »
When this happened to mine I got away with slightly longer screws for a while, but in the end I simply installed helicoils and put the original screws back in - aside from a new carb body I think this is the best fix.
John
Logged
A starter clutch thread:
briancwynn
Enthusiast
Reply #4 on:
September 21, 2016, 11:17:44 am »
All,
I did the TAP and it worked great. Went to 8/32 and nice and tight.
Thank you.
Logged
Honda CB750 1978 K
Stock Carbs w/ Pods
M-unit
ekpent
Reply #5 on:
September 21, 2016, 12:23:09 pm »
Thought that might work, the other fixes are still in your back pocket up the road if need be.
Logged
kidrcth
Enthusiast
Reply #6 on:
September 21, 2016, 07:21:20 pm »
I personally hate helicoils. So I understand why I haven't seen that posted. However working in aviation we use thread inserts. It's an entirely encapsulated thread that screws into the material and you either stake it or glue it in place. Rarely ever strip out.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
