Author Topic: Brake repairs  (Read 2064 times)
Offline Kevin D
  • SE Michigan
Brake repairs
« on: September 18, 2016, 05:36:36 PM »
 I made a couple of brake repairs on Saturday, just in time to ride to the All Clubs Day vintage bike meet in Stockbridge today.
 Last time out I had noticed some front brake chatter. When I checked the disc post ride, it was dirty so I gave it a good wipe down. Later, I noticed that my lower left pant leg was spattered. I went back to the bike and split the caliper, and darned if the piston wasn't leaking.
 The piston is original, the seal, pads, brake lines were changed 9 years, 20000 miles past, and it didn't leak for all that time, or any other time as well. I'm guessing as the pads wore, the seal came to ride on the rough spot on the piston and caused the leak.
 The caliper arm was also original, and had shims added at the hinge pin to combat free play. I noticed a rub mark on the bottom where the arm hub been riding on the disc! I eyeballed about 1/16" up and down play at the tip of the caliper arm, too much in my book.
 I contacted member Godffrey and got new parts including pads, refurbished caliper arm (no slop), phenolic brake piston, no more rust, seal from dealer, all installed successfully.
 Beautiful day here today, great for riding, big turnout at Stockbridge, met Sean, saw and heard his Yosh equipped CB, lots of nice bikes. No leaks and good brakes for my CB, woohoo!
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline Thekramer666
Re: Brake repairs
« Reply #1 on: September 18, 2016, 05:57:45 PM »
Godffrey sells pistons? Can u link me his member page?
Please check your messages & follow up on your posts!!
76' CB550F SS
Offline Kevin D
  • SE Michigan
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
Offline RevDoc
Re: Brake repairs
« Reply #3 on: September 19, 2016, 07:20:25 AM »
I also was not aware of Godfrey's brake work. Thanks for the referral, Kevin!  8)
Dana
'78 CB550K--Angie
'82 CB750 Custom--Eva
As soon as you straddle a bike expect every other driver on the road to suddenly start competeing for the title "Dumbestsonofa#$%*inallNorthAmerica!!"
Re: Brake repairs
« Reply #4 on: September 19, 2016, 07:35:18 AM »
another +1 for Godfferys work.  Top shelf.
Offline Kevin D
  • SE Michigan
Re: Brake repairs
« Reply #5 on: September 19, 2016, 07:50:40 AM »
Knowing that my piston was rough, I went to Godffrey for the phenolic/non-metallic/wont rust piston. I was pleasantly surprised to get the caliper arm and pads from him as well. Also saw double disc kits in his gallery.
I also found a replica caliper arm at Yamiya $$$ and was about to put it on my Christmas list :)
OE part NLA at David Silver/partzilla/etc :(
Choice of Aftermarket or OE piston at David Silver.
I'm 63 and expecting to never again need to work on this stuff, maybe just flush the fluid once in a while.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
Offline DaveBarbier
Re: Brake repairs
« Reply #6 on: September 19, 2016, 11:41:59 AM »
+2 on Godffery's work. I did his dual disc setup and love it.
Offline Kevin D
  • SE Michigan
Re: Brake repairs
« Reply #7 on: September 19, 2016, 06:06:29 PM »
Are any of you using the phenolic brake piston?
Anything to say about it?
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
Offline DaveBarbier
Re: Brake repairs
« Reply #8 on: September 19, 2016, 06:58:15 PM »
I'm using two. As far as performance goes they work the exact same (some say they insulate the fluid from the heat generated by the pad on disc friction preventing brake fade...most of us aren't racing so I don't think this is an issue) but the benefit is in longevity. They don't rust or pit so they'll last longer than your bike most likely.
Offline Old Moe Toe
Re: Brake repairs
« Reply #9 on: September 20, 2016, 12:31:55 AM »
Hi Dave
What type of master cylinder did you use with your dual disc set up?
I used a David Silver early Goldwing replica one, it looks good but I am less than chuffed with how it works.
Offline DaveBarbier
Re: Brake repairs
« Reply #10 on: September 20, 2016, 04:15:37 AM »
Hi Dave
Hey Old Moe,
On my 550 I'm using a Nissin aftermarket 14mm. This one to be exact. https://www.ebay.com/itm/152060668622
I don't have any issues with using the stock 14mm sixe, I like the feel a lot. I'm using stock calipers, too.
