Author Topic: having a heart attack  (Read 2149 times)
Offline Rootcellar
« on: September 19, 2016, 10:15:53 AM »
I was moving some stuff around in the shop and noticed that i have a little chip at the bottom of one my cylinder walls. about 1/8" high by a little less than a 1/4" long...
Please tell me that I am not screwed....
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: having a heart attack
« Reply #1 on: September 19, 2016, 10:23:23 AM »
This post has no context
Offline Rootcellar
« Reply #2 on: September 19, 2016, 10:25:24 AM »
no context?
« Reply #3 on: September 19, 2016, 10:26:02 AM »
that part of the cyl wall is not in contact with the piston or rings.
Post a picture of it.
Offline Rootcellar
« Reply #4 on: September 19, 2016, 10:28:13 AM »
I don't have a pic at the moment, but it should be fine? it's right at the bottom of cylinder 4...sorry, I saw it and ran to the computer panicking...
« Reply #5 on: September 19, 2016, 10:31:08 AM »
go take a picture
Offline Rootcellar
« Reply #6 on: September 19, 2016, 10:31:46 AM »
here is a pic
« Reply #7 on: September 19, 2016, 10:46:24 AM »
Bummer.  Bigger than I thought.
If you are in the US, cheap cyls can be had on ebay.
« Reply #8 on: September 19, 2016, 11:06:11 AM »
I would at least check how far the piston goes, it could still be ok.
« Reply #9 on: September 19, 2016, 11:12:04 AM »
My only concern would it might be really hard to get a ring past that without damaging it.
If you're going to punch it out, get a different head and save the worry  :-\
$50
http://www.ebay.com/itm/Honda-CB750f-Cylinder-sohc-1976-/172322303659?hash=item281f35aeab:g:eXAAAOSwFdtXw5cw&vxp=mtr
Offline Rootcellar
« Reply #10 on: September 19, 2016, 11:57:33 AM »
I have the original block for the bike...this one was already bored out...that's why I'm peaved....
« Reply #11 on: September 19, 2016, 12:06:20 PM »
More worries about where that piece has landed?
Inside engine and runned after that, or just in the garage?
Must be a problem when piston with rings going in.
CB750? Look like 836 thin sleeves
Offline Rootcellar
« Reply #12 on: September 19, 2016, 12:24:10 PM »
Luckily the engine is completely apart as I am rebuilding it ....the chip is on the floor somewhere...i checked the piston vs the crack and it seems like it would be okay as I am just barely seeing the wristpin at it's lowest point...my biggest fear is as calj737 suggests, that the heat and daily use will just make it worse ...think i am just going to resleeve, or just send my original block to be bored out...it'll prolly cost the same either way...thanks for the help guys...
« Last Edit: September 19, 2016, 04:32:26 PM by Rootcellar »
Offline Rootcellar
« Reply #13 on: September 19, 2016, 12:53:14 PM »
Yeah PeWe they are 849
« Reply #14 on: September 19, 2016, 09:30:58 PM »
So the easiest way..ask on here for a pooched 836 sleeve.. Install it, check deck..then bore that one to fit your piston..
