Author Topic: Honda CB750 K1 Intermittent Stalling When Selecting First Gear  (Read 792 times)
Offline Martyn A
« on: September 21, 2016, 07:45:48 AM »
Hi
Recently purchased my CB750 K1 which has been stood for a considerable time and have problem usually on start up from cold of the bike jumping forward or stalling. Also have trouble selecting Neutral when stood- usually have to use kill switch and rock back and forward then no problem selecting. Has anyone experienced any of these problems and any tips how to rectify.
Offline Scott S
Re: Honda CB750 K1 Intermittent Stalling When Selecting First Gear
« Reply #1 on: September 21, 2016, 09:03:24 AM »
 Sounds like a clutch issue.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #2 on: September 21, 2016, 09:27:31 AM »
Hi
Plates sticking.  Adjust your clutch.
Confirm you are using an oil rated for wet clutches.
« Reply #3 on: September 21, 2016, 10:01:50 AM »
 You did not say how much you have driven it so far but may get better if adjusted correctly with more use if the bike has stood for a long period. Fresh proper oil if not done already would be a good thing. As far as the neutral issue others have that same problem also, your not alone. I snick mine into neutral when I want it while I am slowly coasting to a stop.
Offline Martyn A
« Reply #4 on: October 13, 2016, 10:41:00 AM »
 :) Thanks for the Advice !! The slipping in to Neutral when rolling to a stop really works  :)
« Reply #5 on: October 13, 2016, 03:40:15 PM »
Oil with friction modifiers should make it slip not stick. Mine was clunking pretty bad when it was cold and had sat for a while. Om the last oil change I used a quart of Valvoline synthetic along with my usual oil.
 I rode it hard and let the clutch slip a couple times, It got better, someone else recently reported success with,,, was it Bardahl? something like that.  An old school additive.  I bought whatever it was, I'll check the garage.
Offline Dunk
« Reply #6 on: October 13, 2016, 07:15:47 PM »
I had this problem with previous bikes. Solution was always take the clutch apart it clean it well with brake cleaner, reassemble, adjust.
