Author Topic: Battery ground cable/wire  (Read 671 times)
Offline greenjeans
  • 1972 CB750K2
« on: September 22, 2016, 06:58:36 am »
1970 CB750K
relocating battery under tail section.  Is there any reason why I couldn't just weld a bung to the frame closer to the battery ?    Or, is there a reason that it is on one of the motor mount bolts ?   Probably overthinking things.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
Re: Battery ground cable/wire
« Reply #1 on: September 22, 2016, 09:20:36 am »
So long as the mount is clean of paint, you'll be OK.
You should also have a harness ground.
--Evan
1975 CB750K "Rhonda"
Offline 540nova
« Reply #2 on: September 22, 2016, 12:24:11 pm »
I like to clean all ground connections of paint and powdercoat, and use conductive grease on the connector and frame.
