Author Topic: Flat throttle at mid throttle, not RPM  (Read 704 times)
Offline ksmith0034
  • When I grow up I want to be a
    • Please subscribe to my motovlog
« on: September 22, 2016, 06:32:45 PM »
CB750 K1 with pods and 4 into 1.  Runs like a top up to about mid throttle then falls flat. Picks right back up from about 3/4 throttle through WOT.
Can't remember jet size, but i upsized and moved the main clip according to research on this forum.  My question is this: is my flat spot more likely to be jet size or needle location? (Not looking for pod vs airbox discussion)
« Last Edit: September 23, 2016, 07:40:49 AM by ksmith0034 »
It took 10 years but she's finally done!
Stocker 2 Rocker CAFE conversion
My YouTube channel HERE:
https://www.youtube.com/MotoCafeRacer
Re: Flat throttle at mid throttle, not RPM
« Reply #1 on: September 23, 2016, 07:16:37 AM »
If you truly are at mid throttle (because you marked your control and grip beforehand  ;) ), and you go by those jetting overlap charts... you have the pilot jets though-put maxed out, are in the meat of the needle jet, and the main jet is just starting to kick in.  This area is all needle clip range.
IIWM, and I knew my pilot jetting was spot on, perfect plug color, I would move on to doing 1/2 throttle plug chop, and do it as accurately and as long as I could.
New plugs into a hot engine, and ride right in that 1/2 throttle position where the bike chugs.  Your plug color will show you what to do.
Post a pic of your results.
Offline ksmith0034
« Reply #2 on: September 24, 2016, 06:01:29 PM »
Yep, it was the needle. I moved it one clip notch back to the stock position and now it runs like a top!
« Last Edit: September 25, 2016, 04:54:54 PM by ksmith0034 »
« Reply #3 on: September 25, 2016, 04:22:48 PM »
Yep, it was the needle. I moved it one clip notch back to the stock position and not it runs like a top!
Ahh...sweet!  8)
