Author Topic: Rebuild  (Read 924 times)
Offline Quigley14
Rebuild
« on: September 23, 2016, 12:36:25 PM »
I am rebuilding a 1979 cb650 and i improperly replaced the battery. The new battery has its terminals on the opposite sides of the old one so in short i toutched the positive wire on the bike to the negative terminal on the battery. Sparks flew and i fried some sort of fuse attatched to the positive wire coming from the bike, does anyone know the name of this part or where i can find it?
Offline DennyK
  • Just kill the one with the sword first. R. Shaftoe
Re: Rebuild
« Reply #1 on: September 24, 2016, 08:04:01 AM »
Check out Hondaman's web site.   Mark sells a fuse replacement upgrade that uses modern blade fuses.  It is a direct plug and play and could be a solution for you.  I used this on my CB750 project
