Author Topic: R6 Fork Swap information gathering  (Read 17698 times)
Re: R6 Fork Swap information gathering
« Reply #25 on: October 02, 2016, 12:31:38 PM »
Depends if you are drilling through a rib or not in the tree, they can be thin in certain areas, and bard to get a flat seat for the fastener.. Have a look at the underside.
Offline Scott S
« Reply #26 on: October 03, 2016, 04:03:56 AM »
Speedo drive was my issue as well. It's difficult finding a 20mm ID mechanical speedo drive. Kawasaki ZRX models use a mechanical speedo drive. I had considered investigating at the time but went the GPS route instead. Still might be worth considering.
 I actually see a few Kawasaki speedo drives. The 20mm I.D., is that to clear the new, larger axle?
 What about speedo drive ratios? Do they differ among brands? In other words, if I got a ZRX speedo drive, would I need a ZRX speedo?
 Also, didn't one of you mention using a Motolanna fender? Which one did you use? They offer several.  I'm guessing it's one with the "even" mounting holes to match up to the ears on the R6 forks.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Scott S
« Reply #27 on: October 03, 2016, 04:09:10 AM »
 I found http://www.dotheton.com/forum/index.php?topic=20952.0 on DTT. Looks like there are lots of 20mm axle speedo drives to choose from, even a few Hondas.
'71 CB500 K0
'81 Yamaha XS650
Offline Camrector
« Reply #28 on: October 03, 2016, 04:48:16 AM »
I used a mottolanna fender. My bud took some measurements and 3D printed some mounts.
Offline Scott S
« Reply #29 on: October 03, 2016, 05:32:59 AM »
 Ah, so you just used the fender portion and not the mounts.
'71 CB500 K0
'81 Yamaha XS650
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #30 on: October 03, 2016, 06:44:33 AM »
Good score Scott. Now let's hope one of those has a speedo drive with the correct ratio.
Offline Scott S
« Reply #31 on: October 03, 2016, 07:02:00 AM »
 That's what I'm trying to find out now. Wonder how I can figure that out?
'71 CB500 K0
'81 Yamaha XS650
Offline Camrector
« Reply #32 on: October 03, 2016, 12:27:54 PM »
I used the fork leg tabs, but still needed to make an adapter to fit the fender mount. I used the motolana xs650 fender. It was close to bolt on but not quite.
Offline Scott S
« Reply #33 on: October 04, 2016, 03:47:20 AM »
  I have found that Honda (and probably Yamaha and Suzuki) were 2240 = 60mph. Kawasaki is 2440rpm = 60mph.
 While the ratios were somewhat standardized by manufacturer, the drives were slightly different to account for wheel size/diameter.
 My task now is to find a bike that used a 20mm axle and an 18" or 19" front wheel.
 Did any of the bikes in this list use 18" or 19" wheels?
20mm
Honda CB400 F 89-90, CBR600 Hurricane 89-90, CBR600 F
Hurricane 91-96, CBR600 SE 96, VT600 Shadow 88-97, NT650 Hawk
88-91, CB750 SC 91-93 & 95-97, RVF750 R RC45 94-95, VF750
C/C2/D 94-97, VFR750 F 86, VFR750 F Interceptor 88-97, PC800
Pacific Coast 89-90, CBR900 RR Hurricane 93-97, CBR1000 F
87-88 & 90-91 & 93-96, CBR1100 XX Blackbird 97, VT1100 C
Shadow 87-96, VT1100 C2 ACE Shadow 95-97, GL1500 88-97, GL1500
Valkyrie 96-97, Honda VF750 C/C2 98. Kawasaki ZX750 Ninja ZX-7
89-90. Suzuki GSX-R750 88-92, GSX-R750 W 92-95, Honda CR125
00-03, CR125 95-97, CR250 95-97, CR250 00-03, CR500 R 95-97.
Kawasaki KX125 93-97, KX250 93-97, KX500 94-97. Suzuki RM125
96-97, RM250 96-97. Yamaha YZ125 96-97, WR250 Z 97-98, YZ250
96-98, Kawasaki ZX600 E ZX-6 93-98, ZX600 F ZX-6R 95-97, VN800
Vulcan Classic 96-97, VN1500 D 96-97, Yamaha YZF750 R 94-97,
FZR1000 94-95, XVZ13 Royal Star 96
'71 CB500 K0
'81 Yamaha XS650
Offline Camrector
« Reply #34 on: October 04, 2016, 04:46:18 AM »
Or be like Dylan and go electric.
Offline Scott S
« Reply #35 on: October 04, 2016, 04:53:04 AM »
 Looks like most of the Hondas on that list use a 17" front tire.
 The VT600 used a 19" (with one model having a 21").
 CB750SC 91-93 had a 19"
 CB750SC 95-97 had an 18"
 GL1500 88-97 used 18"
 Now....to try to confirm speedo ratio!
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #36 on: October 04, 2016, 04:54:13 AM »
 Always a possibility....and probably the easiest route. But I'd LOVE to have the stock '71 CB500 gauges from my first ever SOHC4 on there!
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #37 on: October 04, 2016, 05:09:09 AM »
 I think the Nighthawk SC might be the answer. Used a 20mm axle, Honda speedo ratio and 19" or 18" front wheel.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #38 on: October 05, 2016, 01:06:16 PM »
 I notice that in this diagram, Jimmy makes note that the spacer(s) are for single disc. What's different for dual vs. single disc?
'71 CB500 K0
'81 Yamaha XS650
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #39 on: October 05, 2016, 01:26:47 PM »
Scott,
I can't take credit for the drawings. Franky was kind enough to provide them.
He incerted a picture of the spacers (from my build thread) for reference.
If you look closely you will notice that only one of the spacers has been drilled and tapped for the rotor. I could easily drill and tap for a second rotor if required.
« Last Edit: October 05, 2016, 03:05:44 PM by FunJimmy »
Offline Scott S
« Reply #40 on: October 05, 2016, 01:58:42 PM »
 Ahhh..... just noticed that you don't use the through bolts to secure the rotor like stock. Just tap both sides for dual discs, then.....gotcha.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #41 on: October 15, 2016, 08:55:20 AM »
 One thing I haven't seen mentioned (two, actually):
 * What length/size are the bolts used and where did you find them?
 * Does anyone remember exactly what bearings you had to use for the stem? And for that matter, the hub, too.
'71 CB500 K0
'81 Yamaha XS650
Offline Johnny340
« Reply #42 on: October 15, 2016, 11:46:48 AM »
Is there any concern about these old frames handling the increased stress from all that stopping power?
I'm also upgrading the font end on my bike (GSXR front on a 750 though)
1975 CB750F0 Super Sport
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
« Reply #43 on: October 15, 2016, 12:29:19 PM »
I've never heard of a frame failure (cracked welds or bent tubes) from the added braking force.  Most of that force is distributed across the forks but some gets transferred to the head stock.  I suppose you could reinforce the welds to the head stock.
Offline 540nova
« Reply #44 on: October 15, 2016, 01:37:11 PM »
You would do an endo before you overstressed your frame.
Offline Scott S
« Reply #45 on: October 25, 2016, 04:23:37 AM »
 So... I have these Lester's......
 How ignoramus of me would it be to use them on the R6 swap?
 I ask because if you're going with a modern front end, weight savings is usually part of the deal. Which means aluminum rims (Sun, Excel, etc.). But I have the Lester's. And I like them. And I can sorta visualize the bike with them in my head.
 Pro: They're Lester's. I already own them. They're cool.
 Con: Not as light as aluminum wheels. The front hub would have to be modified to use it on the R6 front end, so it would be no good for anything else. Not sure if the machinist could even trim the hub, being that it's part of the wheel.
'71 CB500 K0
'81 Yamaha XS650
Offline 540nova
« Reply #46 on: October 25, 2016, 06:01:46 AM »
Agree with Cal. In the end, will +-10 lbs really make a difference? I'd wager you would not be able to tell the difference. Do it for the braking, I wouldn't worry about the weight.
Offline Scott S
« Reply #47 on: October 25, 2016, 06:59:05 AM »
 Cal, yes....the R6 forks are conventional.
'71 CB500 K0
'81 Yamaha XS650
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #48 on: October 25, 2016, 08:44:33 AM »
If the weight is unsprung weight it makes a significant difference. Lester mags would be cool but alloy hoops will offer wider rim options. Then you can get better rubber and really take advantage of the suspension upgrade. Why bother if you don't plan on using it?
« Reply #49 on: October 25, 2016, 09:38:32 AM »
I think the conventional-style R6 forks are a good upgrade for handling and braking.  They weigh approximately the same as the stockers but are more rigid and the binders are definitely better.  I suppose you could get away with 1 and have a real weight savings, but the 2 floating rotors and calipers are still MUCH lighter than a single solid cast iron rotor and stock caliper.  The stock rotors are SO heavy.  Cal has a valid point with tires and wheels. It all depends on how wide you go. My Lester was lighter than my spoked wheels.  Aluminum rims are lighter than steel, but rubber is rubber.  If you go big, you pick up weight.
