Author Topic: We're to measure float height on cb550 k3 1977  (Read 1813 times)
Offline Honellie
« on: October 02, 2016, 07:50:04 AM »
Hi all, first post on this site so hello all. My question is on a1977 cb550 k3 with pd46a carbs were do I take the 14.5 mm measurement from, is from the tip of the float with the flat side , or like on the cb550f from the top of the float. Hope this makes sense. All the best mick
Offline alacrity
  • Ride, Optimize, Repeat
Re: We're to measure float height on cb550 k3 1977
« Reply #1 on: October 06, 2016, 02:15:19 PM »
there is a super awesome PDF you can download from a few places on the web that is free and gives really detailed step by step instructions on this particular carb rack.
As for this measurement, it's the highest point of the float, or, if you imagine the carbs hanging from the manifolds on the bike, it's the point of the float that touches the liquid first, because as the liquid then rises, so does the float, and your measurement (on all these carbs) is to be in charge of precisely determining WHERE that happens, and that it happens identically in all 4.  Capeesh?
I recently restored and sold a 77 cb750f, and am nearly finished with a (former basket case) cb750k5.  This is a place to share, learn and enjoy.  I am grateful to and for 99+% of this site's membership.
« Reply #2 on: October 06, 2016, 02:53:18 PM »
For illustrative purposes only.  Your carb will look different, but the measured planes are the same.
Offline Bikegtxcr
« Reply #3 on: February 21, 2019, 03:43:25 PM »
 I know I'm a little late for this post but where did you find your float height? 14.5mm? As in what publication/manual.
Offline sixthwisconsin
  • With an 1855 Springfield, I'm a
« Reply #4 on: February 21, 2019, 05:44:39 PM »
Just do this and don't worry about measuring. This is WAY more accurate no matter how carefully you measure. Your carbs may differ with the drain screw but the principal remains the same. Hook up your clear tube to the drain and turn on the gas.
