Author Topic: Cb750 k3 clutch compatibility  (Read 599 times)
Offline aejmeja1
« on: October 04, 2016, 08:29:23 AM »
Hey folks!
I have a Honda CB750 K3 i believe (the engine number begins 22). I managed to crack the clutch pressure plate while rebuilding it and now need a new part. Which clutch pressure plates are compatible? The K2 looks the same, but seems to have a different part number. Any advice? Which plates will work on my bike?
Thanks in advance!
-J
Offline aejmeja1
Re: Cb750 k3 clutch compatibility
« Reply #1 on: October 04, 2016, 08:49:52 AM »
part number 22350-300-030 is what i broke  >:(
DH
« Reply #2 on: October 04, 2016, 11:26:37 AM »
I believe the entire run of sohc 750 engines take the same part, the differences may be in the center bearing and its center piece, which if I remember correctly, will press out. Someone correct this If it is wrong please...
« Last Edit: October 04, 2016, 11:33:53 AM by DH »
Offline aejmeja1
« Reply #3 on: October 05, 2016, 05:05:48 AM »
Thanks! Thats what I thought as well.
