I am at the point where my rocker arms are disassembled and out of the head, and the cam is just sitting in the cam channels (cam caps removed). the cam sprocket is loose, tensioner is out, etc. however, following the Honda shop manual, it says to just take the chain off the cam sprocket, remove the cam and sprocket, then continue removing the cylinder. but i don't have enough slack in my chain to get it over the sprocket...is this the point where I use the chain breaker, and just break the chain? if I do that, do I need to keep the chain suspended so it doesnt fall off the crank? or will it be safe to leave loose, and it wont come off the crank? I want to be able to do the "attach-and-pull-through" method for my new chain.
Im also replacing the guide, guide pin, rollers, guide rubber bushings, and piston rings while im at it, so thats why I need to take the cylinders off as well...
P.S. how do I make sure the timing is set correctly? I followed the shop manual and put the crank at the "T" mark for 1-4 cylinders, and made sure the cam timing mark was horizontal and the notch was vertical.
