Author Topic: Cb350f fresh top end smoking like nuts!  (Read 13460 times)
Offline jag767
Re: Cb350f fresh top end smoking like nuts!
« Reply #25 on: October 11, 2016, 11:02:37 PM »
That cbr500 looks like it means business crammed into that little 400 frame.  Hope you have an appropriate length swing arm to keep the front end on the ground! ;D
The funny part is the motor is almost the same specs and dimensions of the cb450 motor  ;D. The story behind that thing is kinda funny. When I first built the 350f, the first machinist I went to screwed up the 1mm overbore with way too much clearance and had no useable bike at the beginning of riding season. Being pissed off and just wanting to be able to ride, I went to the honda dealer looking at a vfr800 he had left over for a steal of a deal. I almost picked it up, til I saw the price for full coverage on a new bike. Even more pissed off, I said to myself, I just want a new motor with the style I build in old bikes, and want the cheap classic insurance i'm used to, why is this so hard?!
While looking at a cx500 for a friend, I noticed a nice looking front end in the corner covered in dust. Minutes later, I picked up a 2007 suzuki sv1000 front end, with calipers and Woodcraft bars on it for $125. Right after that i said to myself well we put new engines in old cars all the time, why doesnt anyone do it in bikes? $100 on a 450 frame and $500 shipped for a cbr500r motor with 3k on the clock got me pointed in the right direction.
That bike will take a butt load more money to finish, but i'm very eager to get it done as well.
« Last Edit: October 11, 2016, 11:21:31 PM by jag767 »
Offline grcamna2
« Reply #26 on: October 12, 2016, 07:07:11 AM »
Will you be redesigning the frame and welding new braces into it so it's as strong as you like ?
Offline calj737
  • I refuse...
« Reply #27 on: October 12, 2016, 07:09:16 AM »
This really shouldn't be necessary since the motor is essentially the same specs as the original.
Offline grcamna2
« Reply #28 on: October 12, 2016, 07:19:13 AM »
The lower frame around the engine has already been cut so welding is necessary anyway.
Offline jag767
« Reply #29 on: October 12, 2016, 07:24:22 AM »
And I have to cut out more also. Then a lot is going back in yes. The motor will be used as a stressed member as well.
« Last Edit: October 12, 2016, 07:26:27 AM by jag767 »
Offline grcamna2
« Reply #30 on: October 12, 2016, 07:27:38 AM »
I'd like to see a thread on this project  8)
Offline jag767
« Reply #31 on: October 12, 2016, 10:16:01 AM »
Heh i didnt make one because its not a 4. I can though.
Offline markreimer
« Reply #32 on: October 12, 2016, 11:51:45 AM »
Very curious to here what you find out. i'm just waiting for space to open up in the shop so I can rebuild my '74 350F as well. let us know!
Offline grcamna2
« Reply #33 on: October 12, 2016, 12:20:05 PM »
Yeah,you could do one in the "Other Bikes" section  :)
Offline jag767
« Reply #34 on: October 12, 2016, 02:07:55 PM »
Great, I will do so  :o
As for this problem. I just got off the phone with the machinist. He claims to be 100% positive the orings are there beyond any doubt. He also verified the valve to guide clearance. I am now at a complete loss
Offline markreimer
« Reply #35 on: October 12, 2016, 02:11:34 PM »
Going out on a limb here, could you have forgotten those oil galley o-rings between the cylinder and head? I'm not super familiar with the 350F design as I have yet to open mine up, but I seem to recall there are high pressure oil feeders in there. That, or maybe the head gasket isn't sealing there? It can only be a few things I guess - oil gets past the rings, through the valve guides, or... in from between the block and head, right?
Offline jag767
« Reply #36 on: October 12, 2016, 02:23:50 PM »
Head gasket had a good seal, as can be seen where it delaminated onto the barrels removing it. All the gallery rubber is in. I am honestly at a complete loss right now.
Offline markreimer
« Reply #37 on: October 12, 2016, 02:26:27 PM »
DId you do the leak down test yet? I'm not sure how else to proceed from here. So you've confirmed the rings were installed properly, with correct gap, valve guide clearance is within spec, guides/o-rings are in, hmm... and the piston to bore clearance is good too? Did the pistons show any signs of blow by?
Offline jag767
« Reply #38 on: October 12, 2016, 05:50:38 PM »
I will do the leakdown tomorrow.
For the guys that asked about the frame on that other project, this will give you a vague idea of the plan.
Offline grcamna2
« Reply #39 on: October 12, 2016, 06:46:10 PM »
The leak-down test would have needed to be done before the tear-down.
Offline jag767
« Reply #40 on: October 12, 2016, 06:48:32 PM »
There's an easy fix for that  ;D. If I can't find anything else, then its not a big job to put it back together.
Offline grcamna2
« Reply #41 on: October 12, 2016, 06:57:55 PM »
With a fresh head gasket.  :)
« Reply #42 on: October 12, 2016, 08:28:07 PM »
Have you slipped the cylinders off the pistons and inspected the rings yet? Someone recently had an issue with Cruzin rings that weren't up to spec:
http://forums.sohc4.net/index.php/topic,161003.0.html
Offline jag767
« Reply #43 on: October 12, 2016, 10:59:42 PM »
I measured end gap it was good.
Offline jag767
« Reply #44 on: October 12, 2016, 11:00:29 PM »
Yep, I ordered a couple extra.
Offline nath180
« Reply #45 on: June 19, 2017, 05:02:19 AM »
Realise that I'm digging out an old thread but chasing a similar issue - what was the result of further investigation?
Offline markreimer
« Reply #46 on: June 19, 2017, 07:07:02 AM »
nath - care to explain your issue?
I have a 350F that ran fine for about 30 miles, then turned into a massive smoke machine. #4 is full of oil, the other three are normal. I still haven't opened it up, but it's either the head gasket failing along the oil pressure line, or a broken ring. Hoping to find out this week or next.
Offline SquierA
« Reply #47 on: December 01, 2020, 11:26:44 AM »
Just joined this forum and have the exact same problem as jag767 had in 2016 with his 350F. Did anyone ever find the solution that could be shared here?
Offline markreimer
« Reply #48 on: December 01, 2020, 02:11:48 PM »
are you also using the cruizin image big bore kit? If so, as far as I know, you are hooped. I did three engine rebuilds with my 393cc kit and they all failed. I had two different machine shops verify the piston to bore clearance was correct. no oval/hour-glass shape to the bores. new valve guides, seals, etc.
When I'd pull the head off I'd find the pistons under a pool of fresh oil. Not just a bit...like a table spoon at least, maybe more. It went through a litre in under an hour. Oil spit out the pipe constantly. The CI rings are garbage.
I'd look for OEM Honda pistons and rings. If I still had the 350F, I'd have looked at using 400F pistons instead.
Offline SquierA
« Reply #49 on: December 02, 2020, 11:32:21 AM »
Thanks for the reply Mark. Yes I am using a piston kit from CI however I went with 0.50 over size pistons instead of the big bore kit. The machine shop I use does great work and has bored several CB500/CB550 motors for me so I am confident his work is spot on. I did order a set of HONDA factory 0.50 over rings on ebay yesterday. In addition I remembered the machine shop calling me when they did the head work and said the valve stem seals wouldn't fit and it appeared the head did not use them. After a quick parts schematic search by me looking at the "valve" schematic I confirmed the valves did not use valve stem seals. After researching more yesterday and viewing the cylinder head schematic I was wrong and the head schematic shows valve stem seals are used on the intake and exhaust valves so I ordered a set today from 4into1 and a Lyle #36050 valve spring retainer tool so I can add the seals without taking the head off the bike. I did see several posts that some of the CB350F heads only had valve stem seals on the intake side. Do you have any info on this? Like I said the Honda factory cylinder head schematic shows both the intake and exhaust valves using seals. I appreciate any input you can provide.
