Author Topic: CB550 Ignition Replacement  (Read 1076 times)
Offline powderfinger77
« on: October 12, 2016, 02:35:36 AM »
Hey Guys,
First post here, but have seen plenty that's helped me out along the way..
I've got a 1977 CB550 K3 in Australia that has a dodgy ignition. Initially I was going to replace it with an aftermarket replica one, but in the meantime I've replaced the headlight with something that has a larger bucket than the original, so the ignition no longer fits.... (oversight..)
I've not got to use a smaller ignition but can only find something suitable with 3 wires. My original ignition has 5 wires. I'm not exactly certain on what each wire does & the only wiring diagrams I can find are shown with 4 wires and not 5??...
Can someone tell me what each does? I'm aware the red & black connect to provide power, but I also have:
Brown
Brown/Black
Brown/White
I'm thinking one maybe the parker light which I can ditch, but how do I wire the remaining 4 wires (red, black, 2x brown) into a 3 wired ignition.
The options of the new ignition are: Off-Ignition-Light
Not sure what other info people may need to provide some advice?? But thanks to anyone that can point me in the right direction!
Cheers
Offline calj737
  • I refuse...
Re: CB550 Ignition Replacement
« Reply #1 on: October 12, 2016, 03:24:30 AM »
RED is battery +(through a fuse from battery to key)
Solid BLACK is switched 12v to the harness. It ends up feeding handlebar switches, KILL/RUN, Regulator, etc.
Solid BROWN is used to power the Tail light (usually through a fuse after the key switch)
BRW/WHT is used to power the gauges and provide head light switch power (through a fuse after the key switch)
I'd suspect the BRW/BLK wire you have originally is routed through a Clutch Safety switch and on to the KILL?
Many aftermarket key switches are junk and not properly rated for the amperage that runs through them. A good idea is to install a relay to help control the power to them. This may also allow you to incorporate your extra wire(s) as you deem necessary to complete the modification.
Offline rickmoore24
  • Be led by your dreams, not pushed by your problems.
  • I <3 SOHC4's
    • Rosenbard Films
« Reply #2 on: October 19, 2016, 02:22:54 PM »
You can also find another stock ignition and relocate to the tree/handlebars area. I agree with the aftermarket switches being junk. Especially the EMGOs, I had one burn out on me inside of a month.
1972 CB750 K2 (Daily Runner)
1972 CB750 K2 (Sold)
1973 CB750 K3 (Hardtail 836cc)
1998 CBR F3 - R.I.P., went down on the 101 in Calabasas, Ca.
1995 EG6
