Author Topic: 1974 CB750 - Front Brake Hose Guide  (Read 749 times)
Offline whitjonw
  • Motorcycle Maniac
« on: October 14, 2016, 03:57:21 PM »
I am getting ready to install my front brake setup from wheel to handlebars. I have everything but the brake hose guide which is number 8 in the attached picture. I tried to order one with my latest parts order but was advised they are no longer available. So, is this part crucial to the setup or can I get away with not having one ? Is it mounted between the triple tree and the 3 way joint ?
If it is definitely needed, does anyone have a spare I could buy from them ?
Thanks,
Jon
1973 Honda CB500 K2
1974 Honda CL200 Scrambler
1974 Honda CB750 K4
1976 Honda CB750 K6
This is our life, this is our song.....
Offline pjlogue
Re: 1974 CB750 - Front Brake Hose Guide
« Reply #1 on: October 14, 2016, 04:21:26 PM »
It's not crucial.  When you tighten the fitting be sure to hold the arm to the bolt in roughly the same position the "keeper" would hold it.  It should stay in this position after the banjo bolt is tight.
-P.
Offline whitjonw
  • Motorcycle Maniac
« Reply #2 on: October 15, 2016, 04:16:29 AM »
Will do, thanks for the help.
1973 Honda CB500 K2
1974 Honda CB750 K4
1976 Honda CB750 K6
