Rob’s (aka Artracing) 1974 CB750K4 Bimota HB1 Clonehttp://forums.sohc4.net/index.php/topic,155346.0.htmlFrame/Suspension:
Custom HB1 stressed-member frame by FrameCrafters
HB1 Carbon Fiber tank
Carbon Fiber seat with leather upholstery
Carbon Fiber front fender
Replica 35mm Ceriani forks
Custom 45mm Offset Triple Clamps with 2.5mm and 5mm offset bushing for 40-50mm range
Engine/Performance:
Megacycle Cam
K&N Air Filter
Custom Oil Pressure Gauge by Rob
Dynatek Electronic Ignition
Solid State voltage regulator and rectifier
Custom oil tank by Ian Halcott
Dual Brembo F08 calipers with modified hub and drilled rotors
Custom Bimota dash
4X4 Custom Exhaust with hand bent megaphone silencers
Paul's (aka IrishCBRacer) 1976 CB550 Cal Crutchlow LCR Honda Restomodhttp://forums.sohc4.net/index.php/topic,85767.0.htmlCustom fiberglass tail with welded steel hoop
MotoGP Werks exhaust
Custom Ohlins shocks
Custom braced swingarm
Benelli style tank
Custom rearsets
GSXR front
Completely-rebuilt motor with knife-edged crankshaft
CR carburetors
Custom aluminum front fender
Motogadget electronics and switches
Rizoma accessories
Signed by Cal Crutchlow:
Nice photo with Cal and Lucio Cecchinello
One of these can really go fast:
Denny’s 1974 CB750K4 Resto-stunnerhttp://forums.sohc4.net/index.php/topic,158971.0.htmlFrom this:
To this:
Removed the engine from the frame and did a top end. We replaced the rings, had the valves ground and honed the cylinder head; including all new gaskets, O rings and oil strainer.
Rebuilt carbs, and installed new OEM (from YAMIYA) engine and air box rubber connectors
Polished all the aluminum engine parts
Painted the engine
Re-chromed the rims, fenders, handlebars, tail light, and other small parts
Replaced front and rear wheel bearings
Replaced old spokes in front and rear wheels with new stainless steel spokes
Put on new tires
Sandblasted the frame
Powder coated the frame, swing arm and other frame parts
New master cylinder and front brake pads
Replaced rear brake shoes
Rebuilt the swing arm with new bronze bushings
Installed All Balls steering head bearings
Rebuilt the front forks with new progressive springs
Installed Hagon Shocks – $$$ love 'em!
Installed new handlebar controls – right and left
Installed a new wiring harness; upgraded to electronic winker
Installed new Oregon Motorcycle Parts, rectifier and voltage regulator
Installed all new OEM cables (throttle (2), clutch, speedo, and tach) from YAMIYA
Installed Hondaman's Transistorized ignition and blade fuse box
Installed new MAC 4 into 2 exhaust
Modified the headlight mounts and front turn signals; did away with the gators
Repainted the tank and aftermarket side covers custom candy orange
Recovered the seat
