Alright guys, so I finally had some time to pull the engine from the frame and get the pistons off...well you guessed it, no. 4 rod wiggled alot up and down! I'll post a video of it.
That's def the issue. I'm very glad I decided (all credit to you guys, thank you so much everybody.) to dig deeper.
Couple questions, any tips on how go remove the alternator rotor? I think i do have the puller, but I just can't loosen the bolt! It is standard threaded or lefty? Do I need to remove the rotor? I'll try my impact on it today, as it was getting pretty late when I got to that point last night
are retaining clips and wrist pins reusable?
Aren't their numbers stamped on the back of the crank cases to display what model of engine it is? Mine has a bunch of "C"s stamped on the back.
While I'm here I'm gonna rebuild the forks and paint the frame and get some welding done for an aftermarket seat I ordered.
