Author Topic: 78 GL1000 20 year sleeper! Old Blue.  (Read 77413 times)
Offline Johnie
Re: 78 GL1000 20 year sleeper! Old Blue.
« Reply #375 on: July 22, 2025, 11:36:52 AM »
The headlight system is designed to go out when you crank the starter. Designed that way to give the starter all the juice.
« Last Edit: July 22, 2025, 05:47:44 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #376 on: July 24, 2025, 01:06:32 PM »
 Agreed, I mentioned it because I think that indicates the starter switch hasn't failed. I's also suspicious of the starter relay, My 79 wanted a strong pat on the sidecover before it decided to crank the engine.  It got a lawn tractor relay. I need to look but this one could be an ebay replacement. I drank a lot of beer since I worked on it.
« Reply #377 on: August 20, 2025, 07:18:02 PM »
  I've ignored old blue's starting issues, here's a picture of the windjammer mounted driving lights. The lights are old 1940's car housings with new 12V clear fog light bulbs installed.
« Last Edit: August 20, 2025, 07:20:24 PM by Don R »
Offline grcamna2
« Reply #378 on: August 20, 2025, 08:49:07 PM »
Nice protective Vetter and Lowers ! Don.\
Love that blue.
75' CB400F/'bunch o' parts'
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #379 on: August 21, 2025, 07:43:10 AM »
Yes, good blue.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #380 on: August 22, 2025, 11:15:46 AM »
 Due to my excellent deductive powers, I've determined that old blue has a bad start button. If I push it in just a little, it starts fine every time. If I push it all of the way in it stops cranking.
 Next up, where to get a proper replacement?
 Edit, no original controls seem to exist, I'm looking at a K&S universal right control or one from another Honda that has replacements available.
« Last Edit: August 22, 2025, 04:24:23 PM by Don R »
Offline Mikey G.
« Reply #381 on: August 22, 2025, 06:31:17 PM »
Do you have a pic of the controls?  I MIGHT have a spare, oddly enough.
That said, any year GL1000 controls SHOULD work.  I think all they did was change the outer casing- the internals should be the same.  My main bike is a '76, so I'm about 75% sure.
« Last Edit: August 22, 2025, 06:35:26 PM by Mikey G. »
-1970 CB750 K0
-1980 KZ1300
-1976 Yellow GL1000
-1965 CA77 "Dream"
-1997 Valkyrie
-1975 Velosolex
« Reply #382 on: August 22, 2025, 10:27:55 PM »
 Here it is, not all faded like most of my 750 controls are but looks worse in the picture. You wouldn't know it's lived indoors its entire life it needs detailing. I did 965 mile days on it two times.
« Last Edit: August 22, 2025, 10:31:43 PM by Don R »
Offline Mikey G.
« Reply #383 on: August 23, 2025, 05:32:33 AM »
I DID have one.  I think I bought it for my old '77 Goldwing before finding out they got changed switch housings in '78.
All the wiring looks intact, but I've never used it.
-1970 CB750 K0
-1980 KZ1300
-1976 Yellow GL1000
-1965 CA77 "Dream"
-1997 Valkyrie
-1975 Velosolex
« Reply #384 on: September 06, 2025, 09:28:50 AM »
 I got a wild hair and bought a new control for a gl1100, hopefully it will wire up similarly. It's odd the aftermarket replacement parts skip over the gl1000, they fit 750, 900, 1100.
 I'm carrying a jumper wire and a remote start switch.
Offline grcamna2
« Reply #385 on: September 06, 2025, 10:32:56 AM »
Looks good.
« Reply #386 on: September 15, 2025, 01:14:49 PM »
 While spraying pb blaster on the control screws I accidentally cured whatever was going on inside it. I'm not trusting it yet but am not looking the gift horse in the mouth either.
