Author Topic: 15A fuse on CB350F  (Read 2620 times)
Offline auro
    • photostream
15A fuse on CB350F
« on: October 23, 2016, 01:51:03 PM »
Hi guys
I've taken my bike for a ride to the harbour, for a good cold beer, today.
As I tried to start it to come back, no sign of life.
I suspected a broken/empty battery, and ended up calling for road assistance.
We found the main fuse gone, although he didn't look bad at sight.
The guy had a 25A fuse with him, we've put that in and the bike started and brought me home.
Now here's a thing: with the 25A fuse in, the neutral/oil signals are on, even if I turn off and remove the key...???
Isn't that odd?
I ended up leaving the bike in the garage without the fuse tonight.
Just wondering if you know what's going on ( I know nothing in electrics)
CB350F (1975)
Offline Bodi
Re: 15A fuse on CB350F
« Reply #1 on: October 23, 2016, 03:56:34 PM »
A fuse rarely just blows for no reason. Putting a higher rated fuse in to replace a blown fuse is never a good idea.
Those lights on are saying "something is wrong".
Possibly a short melted wire insulation and some wires are now crossed? This is not good - there's a single red wire from battery to switch for fused-unswitched power and it's apparently connected to the oil and neutral lamps. 25A is enough to overheat and melt the wire gauge in the harness (metric size close to 18AWG).
Offline auro
    • photostream
« Reply #2 on: October 23, 2016, 10:46:16 PM »
Bodi - thanks for your response.
I didn't leave the 25A fuse on, if not for the time to get home. I'll put a 15A fuse on it as soon as I can find some, and will check the cable you mention.
What I find odd is the console lights staying on even if I turn the key to off and remove it!
CB350F (1975)
« Reply #3 on: October 24, 2016, 06:55:57 AM »
If you have not already done so, please clean all of the harness connectors, and treat them with dielectric grease.
Dont forget the block connectors between the gauges and the headlight bucket.  Each male/female blade connector can be removed and cleaned.
Resistance in your harness is a terrible thing.
Offline ADW
« Reply #4 on: October 24, 2016, 11:21:53 AM »
Has to be a short to those circuits then. Start checking those first.
Offline gtmdriver
« Reply #5 on: October 24, 2016, 11:45:26 PM »
Yes! If anything at all is switched on with the ignition switched off then there has to be an unwanted connection between the power source and the item that's working incorrectly. That's probably what blew the fuse in the first place.
Offline auro
    • photostream
« Reply #6 on: October 26, 2016, 12:51:43 PM »
I understand guys, but it just was working correctly until I stopped for a beer, no issue before at all!
How do you want me to check for shorts?
Shall I follow the cables from the signal lights?
Of course I will put back a 15A fuse first  ;D
CB350F (1975)
Offline b52bombardier1
« Reply #7 on: October 26, 2016, 01:53:42 PM »
Me personally,  I'd disconnect most things first and then replace the fuse. Start reconnecting things one at a time and when the fuse melts, at least you will know what branch circuit to further investigate.
Rick
Sent from my SAMSUNG-SM-N900A using Tapatalk
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
Offline ADW
« Reply #8 on: October 29, 2016, 11:30:10 AM »
I'd say to disconnect the battery and start looking at the wiring for those circuits (the indicators that are lighting when they shouldn't). Start tracing the wiring from the light bulbs and just keep working your way through the wiring. It may be something so simple you'll say "OH! There it is...that wire is pinched between the XYZ and the 123". It may be as simple as that. Always do the simple thing first.
Disconnect the battery before you start though, you don't want to be fiddling with wiring that may be shorting that has power to it. You could fry something more important.
Offline ADW
« Reply #9 on: November 02, 2016, 01:42:28 PM »
Any reports back on what you found?
Offline auro
    • photostream
« Reply #10 on: November 02, 2016, 04:21:23 PM »
Hi ADW and all
Thanks again for your replies and suggestions.
I've been too busy lately with family related business to get to the garage and follow them to the root cause of the issue, but I promise to report back asap!
CB350F (1975)
Offline auro
    • photostream
« Reply #11 on: November 12, 2016, 05:04:12 AM »
Good day all fellow SOHC riders
So I went to the garage and put a new 15A fuse on - it didn't pop.
However, the oil and neutral lights were on, even with with the ignition key turned off, exactly as reported before.
I proceeded with putting a light bulb in place of the fuse, so I could see the light on all the time and started checking the wires on the back of the ignition switch, in the front light and along the chassis
Nothing - light always on - no trace of disconnected or pinched wired as far as I could see.
I did remove the tank to check beneath - nothing
One of the things I noticed is that the turning indicators, once the ignition key is turned on, work left/right and off as I change the switch position... only they don't blink!
I removed the flasher and cleaned its connectors, then tried again - same behaviour (indicator lights on but not blinking) only the flasher makes a bit of a buzzing sound...
any suggestion?
CB350F (1975)
« Reply #12 on: November 12, 2016, 05:39:17 AM »
My guess . . . bad ignition switch.  I'd remove it from the bike and then liberally . . . vigorously . . . spray it through the key hole with electronic contact cleaner.  Use the little red straw to direct the spray accurately and deeply into the switch.  Actuate the switch a lot while doing this.  Spray some more and follow it up with high pressure compressed air to blow out any debris.
  I like Caig's Deoxit D5 electronic contact cleaner and would never use an oil-based solvent - oils attract future dirt. Electronic contact cleaner dries with no residue and removes oxides such as those weird blue-green stains on our old brass bullet wiring connectors.
https://www.amazon.com/s/?ie=UTF8&keywords=caig+laboratories+deoxit&tag=googhydr-20&index=aps&hvadid=60695878032&hvpos=1t2&hvnetw=g&hvrand=917868019797014077&hvpone=&hvptwo=&hvqmt=b&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9025463&hvtargid=kwd-650180056&ref=pd_sl_12jk9en01z_b
Rick
Offline auro
    • photostream
« Reply #13 on: November 16, 2016, 09:51:20 AM »
So yes!
Ultimately it was the ignition switch!
I managed to get a new spare one for a good price and tried it... all perfectly back to normal!!
Thank you all for the advice and suggestions!!!
In the process, I discovered that the winkers' relay also didn't work (fixed) and that fuel comes out of the fuel tap even when closed (not fixed yet)
CB350F (1975)
Offline auro
    • photostream
« Reply #14 on: November 24, 2016, 11:00:20 AM »
first ride tonight after the fix, all good!
imgurl
CB350F (1975)
Online RAFster122s
« Reply #15 on: November 24, 2016, 12:20:16 PM »
 Odds are you bought a cheap Emgo switch.  They are junk and do not hold up.  Consider finding a new one by Honda if possible.  They are worth the money.  Some have installed relays to pull the load off the switch contacts but the switches themselves sometimes go bad under a week or two in some cases.
I hope you get plenty of life from it.  Need to learn how to hotwire the bike in case the switch goes out.  A little creative wiring jumpers does the job.
David
Offline auro
    • photostream
« Reply #16 on: November 24, 2016, 11:45:32 PM »
David
Thanks for the feedback - not sure if it's EMGO but as you say it's likely.
Rick (b52bombardier1), suggested I try and use an electronic contact cleaner for the one I had, which I will try to do at the earliest.
That'd be my plan C, with plan B being the hotwiring as you say...
CB350F (1975)
Offline przjohn
« Reply #17 on: November 25, 2016, 10:15:16 AM »
Damn Beer does it all the time.
