Author Topic: CB400T (Twin) Engine ticking?  (Read 2627 times)
Offline KB02
« on: November 30, 2006, 07:56:58 AM »
A buddy of mine just gacve me a 1978 Honda CB400T (Honda Hawk). her's had the bike for a few years. I actually helped him find and buy it.
Anyway, The bike has a ticking noise at idle. The valve's are adjusted to within spec according to the manual he has as well a timing chain adjusted according to service manual proceedure. And timing is also spot on. It sounds just like my SOHC did when I have a valve out of adjustment which is why my mind is hanging out in the valve train on this.
Is it possible that the valve springs are wearing out and need to be replaced? The bike runs good and stong other wise with no reale problems.
Any idea on where to look?
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline crazypj
  • I'm brill, me
Re: CB400T (Twin) Engine ticking?
« Reply #1 on: November 30, 2006, 09:54:35 AM »
Maybe balancer chain or exhaust gasket leaking?
PJ
Offline KB02
« Reply #2 on: December 01, 2006, 07:23:14 AM »
never thought to check exhaust... Hmmm...
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline KB02
« Reply #3 on: April 03, 2007, 01:15:54 PM »
Well, with the bike running I cannot feel any air puffing out around the headers. It's a little dity, but I can see no obvious evidence of leaks.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Dave L
« Reply #4 on: April 03, 2007, 03:39:03 PM »
HI
If the tappets are the screw type its possable that the valve stems have indented on the end this will not give a correct reading when a feeler is used'
its also possable the ballance chain needs adjusting or replaced.
last thing is the top end getting oil and are you sure it bike oil and not car grade oil
Offline KB02
« Reply #5 on: April 04, 2007, 05:00:16 AM »
Yes, it is Motorcycle oil. Before he parked it, I had helped him with his last few oil changes, so I do at least know that.  ;)
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline HITMAN
« Reply #6 on: April 04, 2007, 05:49:09 PM »
My old 78 Hawk did the same thing, what I found was letting a 'little' clutch out and the tapping would stop.  Turned out the new cam chain was loose, found it was better to adjust it with the engine warm and running.
1974 Honda CB550F
1984 Honda GL1200A
2003 Honda CBR1100XX
